Question about Pioneer DEH-P4100
Pioneer Deh-P4100 beeps, but no music output
I just went to wire this headunit into my 2001 Dakota, and have power, the display works, i can run through all the screens, the cdplayer shows that its working, and the outputs to the speakers beep as you press buttons, but for some reason it does not play music... any ideas?
  • Anonymous Jan 26, 2009
    need a solution
ttech
  • 139 Answers
SOURCE: I cant set my time
Turn power Off And Try Menu to Get to Time Mode..... ttech
Posted on Jul 20, 2007
  • 26 Answers
SOURCE: install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Posted on Feb 14, 2008
merle840
  • 113 Answers
SOURCE: Pioneer DEH-P3500 Output Chip (IC)
PAL007( for sure )
Posted on Mar 28, 2008
Benimur
  • 6966 Answers
SOURCE: Connecting Pioneer DEH-2000MP to an amplifier
Hi and welcome to FixYa,
You would need a special adapter that connects to the speaker wires of the Pioneer DEH-2000MP and converts them to line level RCA ports. Something like the image below and available from here or most car stereo stores.
Good luck and thank you for using FixYa.
Posted on Feb 13, 2009
SOURCE: Pioneer DEH P4100
  1. well to set the clock you need to first hold the source button to turn it off to where the clock is just on. then press and hold the clock button until it beeps then use the arrows to set the clock..........
  2. and to set the stations you need to tune in your fav station and then press and hold the number you want to place that station. you can also do best station memory if you are in an unfamiliar area or if you just want to fast tune all the local stations that come in the best it will randomly preset the stations by pressing and holding till it beeps on the program bottom. then the screen will run BSM until it finds and places the stations. hope this helps!
Posted on Mar 05, 2009
I am unable to reset my pioneer deh p4100. I see
remove the unit and disconnect the battery+red and yellow cables.check the front unit for derfomed plastics or stucked somehow microswitches!someone stucked from the heat!
Jun 05, 2010 | Pioneer DEH-P4100
Everything has froze... I'm stuck listening to a cd over and over... I can't change the volume, I can't skip a song, nothing... pioneer deh-p4100
try pressing the reset switch. should be a pencil tip sized hole on either the face or the subpanel. barring that you can try disconnecting power to the radio for a few minutes.
Apr 28, 2010 | Pioneer DEH-P4100
I have a pioneer deh p310 and all wires match up but a yell/white striped one...is this dimmer or illumination?
if the pioneer deh p310 works ok..then that might b a earth wire....if it's not that then just leave it ...
Nov 15, 2009 | Pioneer DEH-P4100
My Pioneer AVH-P4100 DVD just beeps...
could it be a ground or is the ant. plugged in
Aug 20, 2009 | Pioneer AVH-P4100DVD Car DVD Player
Pioneer DEH-4100 No power
if you dont have a 12volt power supply, you can test the headunit by connecting your yellow, red, and black wires directly to a car battery. connect the yellow and red wires to the positive terminal and the black wire to the negative terminal. Before doing this make sure the red wire has the small inline resistor supplied by pioneer and the yellow wire has a 10amp fuse.
May 19, 2009 | Pioneer DEH-P4100
Hello
Pls verify your wiring. The Pioneer DEH-P4100 uses the below speaker wiring.
whereas a typical 2000 Ford Mustang that does uses an external amplifier would be using the below wiring scheme in its two (2) connectors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 22, 2008 | Pioneer DEH-P4100
Wire Color Code
what color is what on the pioneer deh-p4100
Jul 12, 2007 | Pioneer DEH-P4100
Connecting a amp
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Sep 24, 2006 | Pioneer DEH-1630R CD Player
Pioneer DEH-P4100 Logo
73 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
