Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Hi my bissel proheat 2 will not shoot out water
How do i get my bissell to release water it was fine and now its not working its like its clogged
  • 7 more comments
  • achippett Nov 11, 2008
    i have the same problem with my cleaner. All that shoots out is the cleaning solution and the tank empties in a minute or two. Anyone know what the problem can be and how it can be fixed?
  • jaylioness Nov 27, 2008
    My bisssell proheat 2x the water just stopped, in the carpet and hand tool part. I checked and cleaned away any fiber I saw but there still is no water.
  • chuck1937 Nov 30, 2008
    No water, no cleaning solution, no work at all without solutions!
    I tried letting it idle for 1 minute assuminmg the pump needed priming, per the book, then tried again to no avail!!!
    Please help
  • Anonymous Dec 06, 2008
    Same here - no water coming out of main cleaner - hand tool works fine though.
  • Anonymous Dec 08, 2008
    I have the same problem. The water won't come out of the carpet or hand tool. I've only thad the product for 6 months.
    Had it about 8 months no spray did everything the web sight said still nothing
  • hcr129 Dec 11, 2008
    My hand tools still work but nothing is coming out the bottom, no water or solution. Had it over a year so no more warranty. Any solutions?
  • Anonymous Dec 14, 2008
    Bissell ProHeat will not shoot out water.
  • aaos Dec 21, 2008
    Hand tools OK, but nothing coming out of the bottom
  • 3 Answers
I had this problem, too. My machine is only a year old, so I was hoping it wasn't the pump already. I called the help line, and surprise - no help. They recommended a fix-it place, but the fix-it guy wouldn't help me over the phone. So I fiddled around with it and found the problem - the plug thingy underneath the main tank. The spring mechanism inside it was stuck, preventing any water from going thru it.
Lift out the main tank in the front and bring it to the sink. Feel inside the plug underneath. While holding the tank upright over the sink, push inside the plug. Water should squirt out the bottom of the plug. If it doesn't, turn the tank over, unscrew the plug, and try pushing the inside of it. It is spring-loaded like a ball-point pen. When I pushed the inside of the plug a few times, screwed it back in, and then put the tank on again, the machine worked like new. If your plug doesn't spring, maybe it needs to be cleaned out or replaced. If a new plug is needed, it probably doesn't cost as much as bringing it in for service. It's a small, simple part, and can probably be ordered online. Good luck!
Posted on Dec 29, 2008
  • clarkmom Dec 29, 2008
    There is a plug in the bottom of the cleaning solution tank as well. If your solution isn't dispensing, check to make sure that plug is "springing" too.
My Bissell Won't dispense cleaning solution
Posted on Nov 25, 2008
  • 3 Answers
Earlier someone said to inspect the tank plug, and when inspecting this tank plug make sure the large red gasket is on the tank end of the nipple and not on the receiving end on the chasis.
I had a very similiar problem and spent about 4 hours troubleshooting it, I thought it was a pump or the lines. Check the gaskets, they are the easiest thing and the most probable cause.
Posted on Apr 04, 2009
Try cleaning the two red spray nozzles under the tank. You may have to disconnect the small hose from each and use a small wire. Both mine were clogged...Good Luck
Posted on Dec 18, 2008
Water Tank Not Dispensing Water
The valv is probably faulty. Check also that the water duct to valve is not clogged
Apr 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell, ProHeat, ProTech won't spray water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
895r
Jul 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a ProHeat Bissell 8910 Series. Won't release or pick up
heatman101
yoi
Mar 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
Bissell Carpet Cleaner Won't Release Solution...
heatman101
h
Sep 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat 2x won't release soap water
heatman101
tyu8
Jun 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Apr 04, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
No water comming onto the cxarpet
remove the water tank and pull up those two red tabs unhook them and push something small thru them they are clogged up that is where your water releases it works I just did it and my bissell works great now!
Feb 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1698 PowerSteamer ProHeat Upright will not work. The brushes spin, the soap comes out, but no water is getting to the carpet.
You may try the trigger assembly may not be releasing the water , your brushes spin and the soap comes out but no water – it may have come unhooked or broken, also the water line could be plugged, clogged or pinched and not releasing water to the brushes -- you may try the owners manual for the trouble shooting for the item or check the Bissell website listed below or the customer service phone number of 1-800-237-7691 – the website has a list of trouble shooting listed right on the website I you enter the Model number and hit trouble shooting
http://www.bissell.com/
By Phone Customer Service:
(800) 237-7691
Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Apr 15, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
3,558 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
