Question about Cameras
Looking for tapes for a sonyy camcorder hi8 - Cameras
  • 20 Answers
Many electronic store retailers will have these in stock!
Best Buy - My favorite store
Best Buy - My favorite store again!
Give a call before you head over to any store and let them
know you are looking for HI8 tapes for a camcorder.
Posted on Nov 08, 2008
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
No sound on tape playback.
Are you using the sony software to download and convert the video?
Sep 08, 2008 | Sony Handycam CCD-TRV37 Camcorder
How to cleans hi8 camcorder without hi8 head cleaner tapes
Video-8 cleaning tape will work in Hi-8 camcorder, you can use Video-8 cleaning tape in Hi-8 or Video-8 camcorder.
Thanks.
Mar 06, 2011 | Cameras
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
Problems viewing Hi8 tapes
Seems video head of your handy-cam is dirty or clogged. Use good quality video head cleaning tape to clean video head.
Oct 21, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
How do I transfer hi 8 tapes to DVD without the working camcorder
Greetings jamhere,
I have the same issue myself with my gillion of family tapes and my Hi8 unit broken! The only remedy I have found is to either invest in a new lower price HI8 unit, rent a unit and get my transfers done, or pay to have the old tapes put on dvd professionally. None of these options are too appealing to me, but really seem to be the only options available. If only HI8 had an adapter like VHS-C! I personally would look on some of the online resellers to see if you can obtain a unit that is lower priced to meet your needs. Investing overall in a Hi8 as your only camcorder is not advised, due to it being almost obsolete technology.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
May 05, 2008 | Video Cameras
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Jan 21, 2007 | RCA PRO854 8mm Analog Camcorder
Tape compatibility question.
Yes. Hi8 camcorders are manufactured to work with 8mm or Hi8 tapes. The difference is the quality of the tape. 8mm tapes will provide about 270 lines of resolution where a Hi8 tape will provide up to 400. For better quality recordings, you'll want to use Hi8 tapes.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
