Question about LG Flatron L1750S 17" LCD Monitor
How to disassemble a LG LCD monitor
FLATRON LG L1753s
  • Timothy Tasse II May 11, 2010
    Did you not see the BIG warning sticker telling you not to open?
    With that aside. Why do you need to open it?
    What are you trying to accomplish?
    Champion:
  • 293 Answers
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Posted on Dec 06, 2008
Hi I need help in disassembling a LG W1942T lcd monitor, the problem is (well not really a problem) an ant is sort of stuck inside the screen (right between the outer protective screen & lcd) i sort of crushed it when i saw it crawling on my monitor, not knowing that it was inside the screen! (pls dont laugh...) so its annoying me when ever i look at that particular point of the screen... it would be a great help if you guys could give me a step by step how to on the matter since the tech at LG repair & service want me to pay them alot just to clean it out! thanks for your assistance & have an nice day!
Posted on Aug 24, 2011
LG FLATRON L1753S switching power supply 12dc not working
Plug in the AC ADAPTOR OR CHARGER AND TRY TO SWITCH ON if it runs then your battery is damaged if not then the laptop is damaged
Apr 26, 2014 | Computers & Internet
I have no driver for my lg flatron l1753s monitor, where can i download the driver???
If you want drivers for lg just click this http://members.driverguide.com/driver/detail.php?driverid=983449 then choose the driver you want. Hope it will helps you
Jul 11, 2011 | Computers & Internet
LG Flatron L1753S very bright LCD display how do i remdy this please kindly thank you
You can adjust the brightness with the on screen display controls. This link will get you the manual.
May 02, 2011 | LG Flatron L1750S 17" LCD Monitor
How can disassembly LG monitor Flatron L1717S?
MONITOR CAN BE DISAMBLY BY USING SPECIAL TYPE OF SCREW DRIVERS
Jan 12, 2011 | LG L1717S-BN 17" LCD Monitor
My lg flatron l1753s shows some visual disturbnce like somthing flowing and in few moments shows completely black screen after that normal so......plz tell me what to do to fix it?
It could be the domestic maintenance problem keep your monitor away from moisture and other physical damage it will make your monitor perfect as new working...
Dec 09, 2010 | LG Flatron L1750S 17" LCD Monitor
My computer wouldn't start and it is stuck in power saving mode. its LG flatron L1753S.
check the power cable, make sure you are using the correct video cable and input source and it may help if you try to use a different power cord that is confirmed working. if you use an adapter for it, verify that the adapter is working.
Dec 04, 2010 | LG Flatron L1750S 17" LCD Monitor
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
My LG Flatron L1753s is not working what will be the reason
90% LCD monitors failures are caused by bad caps.
Please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 18, 2010 | LG Flatron L1750S 17" LCD Monitor
How do I Open / disassemble LG Flatron
Remove all the screws from the screen that you can, check for screws under all soft objects and labels, after all screws are removed, use a flat screwdriver or a case opener tool to start snapping the display cover open, it is hold in place with plastic clips, these will clip open but be carefull not to break any.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
Disassemble anlg lcd 19''
The following link will show you the 'pdf file' for the assembly of your monitor.
You should be able to reverse this procedure in order to disassemble it in order to put it back into the box.
http://us.lge.com/download/product/file/1000000449/L1951S-BN.PDF
Go to page 4 and look for "Removing the stand base" to see how to disassemble. Binary Bob
Nov 29, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron L1750S 17" LCD Monitor Logo
2,625 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
