Question about Canon PowerShot A620 Digital Camera
Water damage My Canon Powershot A620 was submerged for a few moments. It powered on afterwards, but I still took the batteries and memory stick out and let it dry. Now it will not power on.... Is there anything I can do?
    Novelist:
  • 208 Answers
PROBABLY NOT, BUT WHAT YOU MIGHT DO IS SEE IF A REPAIR SHOP WOULD AT LEAST TAKE A LOOK AT IT AND SEE IF IT IS AT ALL REPAIRABLE AND GIVE YOU A QUOTE. CHANCES ARE THE REPAIR WILL BE SO COSTLY, IT WOULD BE CHEAPER TO REPLACE THE CAMERA. SORRY, BUT THIS IS ABOUT THE BEST SOLUTION I CAN OFFER IN THIS CASE. YOU CAN FIND CAMERA REPAIR ON GOOGLE UNDER CANON POWERSHOT REPAIR SERVICE. IF I CAN DO ANYTHING ELSE FOR YOU REPLY TO:
ARCLIGHT1217
Posted on Nov 06, 2008
The camera will only let me shoot one minute of video at a time
in the settings you should be able to change that, this happens when your using the camera internal memory and not a external memory stick,
Oct 02, 2011 | Canon PowerShot A620 Digital Camera
I have a Canon SD750 camera. It was the victim of a water flood and I dried the unit completely. After recharging the battery, I couldn't get it to power up. I took the camera apart and found several...
Unfortunately with water damage the camera may work for a few days or even weeks after you first dry it out, but then it will stop working completely. If you have corrosion from water exposure then the camera is gone, it's not worth trying to fix. Even if you replace the main PCB it probably has damage to the lens, LCD screen and flash as well.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon A620 LCD shows "memory card locked" for each card I insert
This worked for me!  I have the Canon Powershot SD780 IS and although my card WAS NOT locked, the camera "malfunctioned" and the switch in the camera needed to be gently pushed back IN, not DOWN on my specific camera type.  This is great, I was just going to go out and buy another camera today!  Thanks for the post Stephan!
Nov 10, 2009 | Canon PowerShot A620 Digital Camera
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
Canon Powershot 870IS accidentally submerged in water.
when the camera falls in the water, only the power supply would have got bad, just take it to the manufacture, he will replace the power unit, it will work as good as the new one,, thank you,, plz rate me
Jun 30, 2009 | Canon PowerShot SD870 IS Digital Camera
Dropped my Canon A620 Powershot briefly in water. Dried it out (took memory card & batteries out). After a few days I turned it on-, and I can't get past the "set date/time" screen (can't...
Your sensor and your inner board is getting malfunctioned so you need to contact canon so that they can check it and repair it .
If it is under warranty it could be solved at no cost .
Thanks for using Fixya .
SAM ANDERSON
Sep 14, 2008 | Canon Cameras
Camera will not power up correctly
Again the same old compact camera zoom lens problems - sand in lens, stuck AF motor, chewed up plastic gears...you only have to look at them wrong and they will die... (A very cynical camera repairer that has tried to repair these damn things soo often!!) Even cameras with internal lenses like the old Nikon 950/990/4500 still have troubles with stuck motors and broken lens parts. I despair - these things are just made to last the guarantee out (if that long) and die horribly afterwards!!
Nov 08, 2007 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
