Question about Sony Handycam CCD-TRV25 Camcorder
Do not know where to plug av to rca 3 cable
I have tried to plug the one male end into the two front receptacles one has an ear and one says mic. Neither allows me to watch the video on my laptop while using a converter called a dazzle 100. any ideas
4 Suggested Answers
SOURCE: Sony TRV128 - Will not transfer sound to DVD
There is an S-video jack in the front of the cam, the S-video cable is rather inexpensive and available at most stores that have electronics.
Posted on Dec 01, 2007
  • 899 Answers
SOURCE: Get video off Sony Handycam DCR-TRV118 Hi8 to PC or Mac
You can use a Digital8 Camcorder to directly play 8mm and Hi8 analog tapes and output them to your computer via firewire Capturing 8mm/Hi8 with a Digital8 Camcorder
Posted on Nov 02, 2008
zohail
  • 1223 Answers
SOURCE: When connected DCR-SR42 to TV, video and images showing in B&W
yes ur TV might be set to color system PAL /NTSC and ur cam corder in opposite format there is color system changing button on every tv remote just try changing it to PAL or NTSC see if colors work and let me know and pls rate me if i fixed ur problem
Posted on Feb 25, 2009
  • 56 Answers
SOURCE: I have a Sony Handycam Vision CCD-TRV36 NTSC video
You can recorded in a dvd recorder and then extract to your mac(final cut pro) that's the best way to do it as pinnacle dazzle its useless or you can buy the capture video card with a fire wire that will recognize you pc mac straight nothing to download
Posted on Aug 01, 2011
AV Cable to television
The CCD-TRV81 uses a standard Composite AV cable. These are available in most electronics stores (and for less at on-line cable shops). These use 3 RCA plugs on each end (red, white, yellow).
Match the colors to the jacks on each side. The manual is available here: www.docs.sony.com/release/CCDTRV81.pdf .
I hope this helps.
Aug 28, 2012 | Sony Handycam CCD-TRV81 Camcorder
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
I cant plug my jvc to my tv .Each time i try,nothing shows up.
I am assuming that you have an AV cable which you need to have connected to your camcorder at the AV output socket, and the other end should have RCA phono plugs (one red, one white and one yellow) which usually connect to three corresponding sockets on the front or side of most modern TV sets, these may be inside a front panel which opens. Once connected, you need to select the appropriate AV input on your TV remote, very often this will be "Front AV" or AV3 or AV4, you need to check your TV instruction manual to be sure of which input is required for your specific model of TV...hope that helps!
Oct 13, 2009 | JVC GZ-MG130U Camcorder
I lost the cord to the computer.
I don't know if you want the AV to Video cable or the DV Interface cable. You should be able to get a mini plug to 3 way (Yellow/White/Red)RCA jacks from any electronics store. The DV interface cable's part number is PV-DDC9 and runs about $45 You can call Panasonic at 800-332-5368 to verify the cable's names and prices.
Jun 08, 2009 | Panasonic PV-DV900 Mini DV Digital...
Where do i plug in a cable to connect the cam to a tv or computer? i only see an ear socket and an ext mic socket on the cam.
On my Panasonic camcorder, the RCA plug-ins are in a separate compartment covered with liftable flap. Try searching for this flap. My flap is next to the battery compartment.
May 17, 2009 | Sharp Video Cameras
How do I connect my Panasonic PV-L353 palmcoreder to my computer
You don't give enough details. More details would help.
I have a Panasonic IQ PV-IQ403 old palmcorder. I know how to connect it to a TV screen. I am not sure how a camcorder would connect to a computer. Maybe this information can be of help to you. I have separate flap door covering my RCA connections on my camera, located near the battery compartment. I just plug one end of the RCA cord into those connectors and the other end into the RCA connectors on my TV. I have to change the power switch on my camera over to the VCR position (take it off of the camera position). The TV has to be on channel 3 (or 4). I push play on my camera, and I can see what I have recorded on my TV screen.
This might work on your computer monitor. I am not an expert, but this information may be helpful.
May 17, 2009 | Panasonic Palmcorder PV-L353 Camcorder
Firewire and playback on TV
I don't know it this will solve your problem but I'm using a 3 pole male plug and getting picture on the TV (but not great picture - see above).
Jan 01, 2009 | Canon ZR900 Mini DV Camcorder
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
Monitor Sound for JVC GZ-HD7
I've never heard of an adapter and after a quick google search and all the options voided the warranty, but if i were to make an educated guess... the easiest way and unfortunately bulky way of doing this would be to use the av jack and the cable that came with the camcorder, take one or both of the RCA stereo ends and pass them through a mic - line level converter and that should work, or you can use one of the stereo RCA ends and use a rca to phono adapter and then connect a headphone volume amplifier to that. Other than those choses, I see no other way to monitor your record volume with headphones.
JVC has been approached about this and they said they didn't include a headphone jack to reduce cost, but seriously. how expensive could that have been?
Oct 26, 2008 | JVC Everio GZ-HD7 Camcorder
Nov 26, 2007 | Sony Handycam CCD-TRV128 Camcorder
Sony Handycam CCD-TRV25 Camcorder Logo
24 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
