Question about Copystar CS-1500 Copier
C6 error has a c6 error
Error C-6 appears on photocopier
Posted on Apr 10, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Copystar Master
  • 1,362 Answers
C6 -----fuser unit trouble
Bad fuse lamp or thermofuse
Posted on Nov 06, 2008
Aeg lavamat error code c6
Found this on the following forum
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/aeg-lavamat-86741-error-t47666.html
C6 is caused by either a) defective mechanical pressure switch, b) defective pressure sensor or c) Defective wiring to either a or b.
You may want to just remove the hoses from the switch & sensor, noting what hose went where & blow down them to see if they are clear. If not, trace blockage & clear, refit hoses & test.
Before doing the above, please isolate the appliance from the mains electric supply.
Jan 13, 2015 | Garden
Ricoh aficio sp 100su has error code c6
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Nov 13, 2014 | Ricoh Aficio SP 100SU e Laser...
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Nested IF functions in excel
Your first IF condition is “=IF(C6>6000,0.15%*(C6-6000),0)”
Where:
C6>6000 is your logical condition
0.15%*(C6-6000) would be the value if your logical condition is TRUE, and
0 would be the value if your logical condition is FALSE.
Your 2nd IF condition is “(IF(C6>30000,0.3%*(C6-30000)))”
Where:
C6>30000 is your logical condition
0.3%*(C6-30000) would be the value if your logical condition is TRUE, and
? would be the value if your logical condition is FALSE.
You are missing the value if it is FALSE.
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Excel (SS8SATAS5128400R)
Copystar CS-1500 Copier Logo
569 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
