Question about Whirlpool Washing Machines
I have a whirlpool front loader, its only 4 yrs old. It is making very loud noises when its on spin cycle
  • 135 Answers
Sounds like drum bearings are going. this is an expensive repair.
Posted on Nov 06, 2008
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
Sep 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
I have LG washer and dryer and its making loud noise, specially when its spinning. Do you have any suggestion. this washer is only 4 yrs old
The most common reason for a loud noise on spin cycle is that water has got into the bearings and forms rust. The ball bearings are no longer smooth. Hence the noise!..Probably the most common F/L washer reason for demise. If the inner bowl is loose and 'floppy', it would be for the same reason.....Overuse of detergent will do it every time!.....Sorry.......Nomess
May 16, 2010 | LG WM3431 Front Load Washer / Dryer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool dryer at least 10 yrs.old
belt broke remove 2 screws under lint screen release clips under edge of top on each corner by pressing in with putty knife..lift top remove screws upper corners each side top ..disconnect door switch connector lift front off install 341241 belt per diagram on bag
Jul 30, 2008 | Dryers
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
89 people viewed this question
Dan Webster
Dan Webster
Sal De
