Question about LG LRBN22514ST Bottom Freezer Refrigerator
How to Install Overload Relay Part #4387535 (hooking up red/blue/black wires)
My 4-year-old LG fridge needs a new "overload relay". I already removed the original relay, which definitely had the classic "broken pieces sound" when you shake it. Like when a light bulb dies and the filament breaks.
I should have taken a picture of the relay while it was still connected to the wires, because now I don't remember which wires to connect to each part. I have purchased replacement kit part (#4387535)
Here is a link to photo of the 2 parts I need to connect RED, BLUE, BLACK wires to.
http://www.partadvantage.com/image/wp_4387535.jpg
As you can see in the photo, the brown part has 4 metal connectors (I don't know what else to call them), and each is numbered (1, 2, 3, 4) I remember that 2 of the colored wires go to 2 of these connectors. And the 3rd colored wire goes to the white part in the photo.
The part came in a plastic bag with no instructions. I'm sorry I don't know the technical terms. If anyone can help with straightforward instructions, I can get my fridge running again!! Thanks!
4 Suggested Answers
  • 66 Answers
SOURCE: The starter/overload and overload protector
The easiest way to find this out , is to check the condenser. Make sure that the condenser is not clogged up with dust and that the condenser fan is working. Replace the start relay. Turn it back on. If it starts right up then it probably overheated and melted the relay due to the condenser fan not working or the condenser clogged with dust. Air circulation through the condenser and air being circulated over the compressor in how it cools itself. If the compressor will not start or if it runs for a little while and then shuts off from overheating, then you have a bad compressor.
Posted on Nov 12, 2008
  • 90 Answers
SOURCE: installing overload relay kit 4387535
go to appliancezone.com
part # 4387835
it goes on the same way it comes off
if you hafe the MBV1976AA -- they use the same part
item is marked 307071
but is listed by maytag # 4387835
Posted on Dec 30, 2008
SOURCE: Installing an overload switch (part #8201799)
I found the part I needed. Thanks anyway.
Posted on Apr 02, 2009
Supco PRO 41 relay/overload combination. Where do blue wire and black wire connect?
before you suffer electrocution and toasted relay / overload accessory , better consult someone familiar with such intricate connections. there ' s supposed an accompanying diagram for the connection. thanks .
Oct 11, 2015 | LG LSC27921SB Side by Side Refrigerator
HELP! - My fridge freezer is not cooling - clicking sound heard but motor not coming on
Hello Michelle;
My name is Peter. I am a retired field service refrigeration technician.
Lets fix this together. The clicking sound that you hear is referred to as a overload relay. The overload relay is an electrical component that starts and stops you compressor. It is very common for the overload relay to fail over time.
First, locate and purchase a overload relay. If you have a Trible's
in your area that's great, if not Lander's, Sear's, .... If you can wait a few days you can get the part over the internet for half price or less.
I do not have your model number otherwise I would give you the part number.
Having the part, pull the refrigerator out where you can move freely behind it. Unplug the refrigerator. There is a bottom cover that you need to remove. This cover is fastened either with Philips or hex head screws. Remove the cover. Open the new overload relay parts and lay them before you. Study and observe them.
There is a black box on the side of the compressor which holds the overload relay. The box is held on with either metal or wire clips. Using a flat head screw driver pop the clips off. Compare the parts on the compressor with what you have. Note the location of the connecting components on the 3 compressor pins, and the first piece to put on the compressor is the white piece with the 'V'. Using your flat head screw driver, wedge the components off the compressor (Remember how they go back on). Do not pull on the wires - just the connector ends. Replace the components. Shake the white piece - if it rattles or is burned it is bad. If you can not get the black box cover back on - not necessary, it's a dust shield.
Note: If you have a LG, bottom freezer 599, do not bother. Both the overload relay & compressor need to be replaced. Buy new, not LG.
Oct 28, 2014 | Refrigerators
Replacing a relay and overload protector with a 3 n 1 hardstart
2 BLACK WIRES IS POWER. ONE GOES TO NEUTRAL, ANOTHER TO THE HOT WIRE(LINE) AND IT DOES NOT MATTER WICH YOU WILL HOOK UP AS LONG AS ONE OF THE BLACK WIRES HAS NEUTRAL, ANOTHER ONE POWER. AND BLACK IS GOING TO COMPRESSOR COMMON PIN, WHITE TO START PIN OF THE COMPRESSOR AND RED TO RUN. I HAD ON THIS REFRIGERATOR START AND RUN CAPACITORS, I ILLUMINATE THOSE - THEY CAN NOT BE IN THE CIRCUIT WITH 3 N 1 HARD START KIT. SOME COMPRESSOR HAVE THOSE CAPACITORS, SOME NOT. I DID NOT UNDERSTAND WHY THIS ONE HAD CAPACITORS IT WAS ONLY 1/3 HORSEPOWER. HOPE THIS HELP YOU.
Jan 01, 2014 | Kenmore Refrigerators
Not sure how to wire Supco RO41 Relay/Overload Combo to Maytag side by side Fridge MSD2454GRW. It's a universal part, so it's different than the manufacturer's part, but I just want to see if...
while i loath those RO41 because your compressor will be dead SOON. The 2 black wires connect to the wires were connected to the wiring on FACTORY RELAY AND OVERLOAD WHICH WAS ORIGINALLY CONNECTED TO WHERE THE RED/WHITE/AND BLACK WIRES WITH THE TERMINALS NOW ARE.
my advice though is throw that thing in the trash and get factory OEM relay and overload
Aug 17, 2011 | Refrigerators
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
Help!i have a maytag refrigerator model #mtb2172hr that stopped getting cold on and off and i hear a buzzing noise on and off around compressor area.the fridge is 5 yrs.old.i hear the motor and fan still...
Sounds like a bad overload relay capacitor on your compressor, or a bad compressor. If it is under 5 years you usually have a 5 year sealed system warrantee that pays for parts and labor on the compressor. It does not pay for a relay overload capacitor. The problem is some warrantee companies will void your warrantee if you or an unauthorized servicer works on your unit. I would recommend you have maytag send out a technician to diagnose this, mainly because I have seen a lot of bad Maytag compressors lately. If it is over 5 years old you can replace the overload relay capacitor and test to see if it works. Before you do this you should remove the old overload relay capacitor from the compressor and do a continuity test between all three terminals and between the terminals and the compressor case. You should have continuilty between the terminals but not between the terminal and the case. If you dont have continuity between the terminals or if you do have continuity between a terminal and the case, then you have a bad compressor. Do not install the new overload relay capacitor as you cannot return these to the parts house once they have been installed. Even after all the tests and even if your compressor starts up you can still have a compressor failure within a couple of days. A technician can hook up your compressor to a tester and determine if it is good or bad. If a compressor is bad it usually costs 900 to 1100.00 to replace through any of the service companies in my area. Not worth repairing. Hope this helps, Appliance Specialists
Dec 15, 2009 | Kitchen Ranges
I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Magic chef compact fridgerator model mcbr445b1
you may just have a bad relay. with the power removed ..(unpluged)
remove the relay cover ( on the side of the compressor)
remove overload and relay
check relay for 4-5 ohms
check overload (if open it is bad)
let me know
Dec 21, 2008 | Refrigerators
Installing new over load relay
The line voltage goes to the overload and the neutral(and capacitor lines if it has one) goes to the relay.
Dec 05, 2007 | Whirlpool GS6NBEXR Side by Side...
LG LRBN22514ST Bottom Freezer Refrigerator Logo
1,317 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
