Question about Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
WAter overflows from the detergent draw fo my washing machine and on 1 program only and then the dial clicks round all without stopping. i have tried cleaning the draw and checked the inlet / outlet hoses swell as the detergent recovery hose inside please help thank you
  • fishu Dec 23, 2007
    Indesit W123 UK water overflows from detergent draw and does not stop watering in.
  • Anonymous Mar 22, 2014
    Water overflowing at outlt
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Posted on Nov 26, 2006
Iwd71250uk fabric softener staying in dispenser.
Compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow the grid.
Cleaning the detergent dispenser drawer
Remove the dispenser by raising it and pulling it out (see figure below). Wash it under running water; this operation should be
repeated frequently.
25825864-ineink0kisfnom0atbkujjcx-3-10.jpg 25825864-ineink0kisfnom0atbkujjcx-3-3.jpg 25825864-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Aug 17, 2015 | Indesit Washing Machines
Indecit W123 washing machine water doesnt heat. The water doesnt heat up in my machine.
More than likely that the heater element has failed,
This is usually located at the rear of the washer, remove rear panel, and test with a meter, this is the only sure way of testing it to see if it is o/k.
Mar 17, 2010 | Indesit W 123 Front Load Washer
Indesit washer w123
take soap drawer out and clean it
Aug 28, 2008 | Indesit W 123 Front Load Washer
Indesit w123 front load
would check pressure switch and the pipe that goes down to the drum for blockages if not may be faulty water valve unplug first regards jason
Apr 28, 2008 | Indesit W 123 Front Load Washer
W123 dispenser drawer keep melting
Hi there you can order the part from indesit and should not cost alot and yes it should withstand the temp check that if you are using the hot tap to the machine turn down the water thermostat as maybe too hot.
Thanks J
Feb 09, 2008 | Indesit W 123 Front Load Washer
Faulty washing machine w123
does the water empty from the machine? if not you will more than likely have something trapped in the pump. the best thing to do is run the grey outlet hose into a bucket, this will empty the machine. then tilt machine back (make sure it wont fall) then remove the plastic kick plate on the front bottom, behind this you should see the round plastic filter this will unscrew and pull out, you may need a couple of towels put on the floor as there is usually water left in the pipes. clean any debris and screw filter back in, should only need to be hand tight. replace kick plate and then give it try.
hope this helps
kj
REMEMBER MAKE SURE POWER IS OFF BEFORE CARRYING OUT ANY WORK.
Nov 09, 2007 | Indesit W 123 Front Load Washer
Indesit w123
the holes above the drawer may be blocked. remove the drawer and scrub the holes with a stiff washing up brush rinse away then try again.
Jun 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
349 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
