Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer not working
We bought a used refrigerator with on top freezer at a garage sale. We had to tip the frig on its side to move it. The frig is working ok but the freezer has stopped.
  • 2 more comments
  • wbose Nov 06, 2008
    Not continually. Ice cubes melt when I put them in the freezer so I know it is not cold enought.
  • Anonymous Jan 22, 2009
    I also had to tip mine to move it and it gets cold but will not freeze
  • iam1sk Jan 23, 2009
    I have a similar problem. My freezer has a sudden frost build up and now the fan runs all the time but the freezer won't get cold. We have lost all our food at this point. This all happened in the last 24 hours. I turned the setting to coldest last night but this morning everything was melted.
  • Joe Carter Feb 17, 2009
    I have the same problem with the frost build up and the motor continues to run. Door is closed and can't see a leak anywhere
    Genius:
  • 1,122 Answers
Is there frost building up in the freezer?mike
Posted on Nov 06, 2008
  • MIKE major Nov 06, 2008
    is the freezer fan working,and what do you have the freezer set on?you must find out if frost is building up so you know if it is a defrost problem,other wise it might have a small leak,let me know-mike
The freezer works but the refrigerator does not work
Could be the fan isn't working inside to send air from freezer section to refrigerator section. If it works for a few days and refrigerator quits could be a defrosting issue.
Jun 16, 2012 | Refrigerators
Slow to cool. bought used only got to 45 in frig. reset on 9 and in 24 hours stay at 38 to 40. But moved to 7 and it is at 45. GE tfh22 PR. Thanks for your input.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi, I bought this Roper Refridgerator at a garage sale, it was going to be a beer/bait freezer for the garage, looks really nice, and was told it worked. Actually it does have the light on and air is...
Hi. Let it sit unplugged for 24 hours after moving it. That will allow all of the compressor oil to settle. Then plug it in and expect it to take another 24 hours to cool. If it does not cool, it is probably low on refrigerant, an easily remedied problem. J.
Aug 10, 2010 | Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool et18gk freezer working frige not
Since we know the machine is producing cold, that is a plus. The cold is created in the freezer. From here, a fan moves it through vents into the frig. From the frig it goes back into the freezer and makes a big loop.
What you probably have here is a motor to the fan in the freezer gone out. If you want to fix it yourself I'd be happy to tell you how. If you want to know if it's worth fixing, I would say most definitely. I would expect $40-$80 for the fan motor then labor on top of that. The fan part number is 2315539.You should be able to order the part anywhere that sells appliance parts by that number with no problem at all.
Jun 02, 2010 | Whirlpool ET8WTEXV (183 cu ft) Top Freezer...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Frig is not getting cold!
How did you transport refrigerator? Standing straight up, or laying on its side???
Jul 14, 2008 | Frigidaire GLRT216TA Top Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
