Question about LG Studioworks 440SI 14" CRT Monitor
Power supply get dropped
What all compoments should be checked
  • 749 Answers
What power supply do you mean Sir/Ma'am.
is it the AVR (automatic voltar regulator)?
if its the AVR, just switch it on and check the output voltage with a multimeter (AC range 250)
you should see the voltage output nearly equal to your SERVICE AC voltage
Posted on Nov 06, 2008
How about the capabilities of Fuzhou Antyco Optics?
We are the manufacture of precision optical compoments, our main products are Optical Windows, Mirrors, Prisms, Lenses, waveplates and Color Filters, we also supply various of coatings.
Most of our technicians have more than 10 years' experience in optics manufacturing filed. Our Optics are sold to USA, Germany, Japan, Canada, Australia and all over the world.
For more: http://antyco.com/
Oct 14, 2016 | Bushnell Optics
Sony dsr 30 no power
Hi
This does sound as if the fault is on the power supply board it is possible one of two things 1 a capacitor that as dryied up or 2 a diode on the sec side of the chopper transformer that as gone short .
You will need a test meter to locate the faulty compoment . WARNING DO NOT ATTEMPT TO repair this board when connected to the mains try to find fault using resistant Test's. If in any dout about this please take your unit to a repair center.Hope this might help
Regards Derrick
May 10, 2012 | Sony Televison & Video
TV had no picture first and then no sound. I have unpugged TV and still nothing happens. There is a blinking red light on that can be seen from rear of TV ( 1 blink on and off). Thanks for your help.
Good day!
Please follow this procedure to fix your problem:
  1. Open the cover of your TV.Remove all screws at the back.
  2. Next,power ON the TV and check the output voltage of power supply using voltmeter.
  3. It should have not less than 5vdc for system board,12vdc for sounds and 24vdc for inverter board.If the 3 supplies are got a voltage drop your power supply had problem.For example if you check the 5vdc then the reading is 4.50vdc only.
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it using soldering iron and soldering pump.
  5. When the power supply looks like OK,no voltage drop and no leak/bulge on top capacitor.The problem is your system board or main board.There's no easy remedy for that.You have to replace the whole system board.
A Power supply is like this..(It is not actually look like yours but it was just for your Idea)
Please let me rate and testify by you when you find my solution helps you...
I hope this solution helps you to fix your problem.Thank you and good luck.
Jul 12, 2011 | Element Electronics FLX3210 32 in. LCD TV
Why does my vizio lcd 47 in tv just suddenly turn off. I will be watching tv and suddenly it just goes off. The vizio power light then blinks steady for about 1 min and then the tv starts up again, as if...
Good day!
  4. If you have voltage drop,check some leak/bulge on top capacitor on power supply.replace it by using soldering iron and soldering pump.
Jun 13, 2011 | Vizio VO47L 47 in. LCD TV
It takes atleast 3 tries before the 37 in led turns on
A pleasant and good day!
The problem could be the power supply.
That problem is usually happen when the output voltage of the power supply got a voltage drop or fluctuation.
This is the procedure on how to fix that problem:
  1. Remove the back cover of your TV.
  2. Plug-in the power cord of your TV and power it ON to perform a voltage data or voltage check.
  3. Test the output voltage of the power supply.Use a multimeter (DC range) then check the 5vdc for the system and logic supply.
  4. If the 5vdc got a voltage drop when you power ON the TV.There's a leak or bulge on top capacitor on your power supply unit,replace it!
Like this:
Watch this video to guide you on how to replace a capacitor.
I hope this solution will be helpful.Thank you and good luck.
Apr 28, 2011 | LG Televison & Video
I have an lg 32lx2r tv the stand by light comes on but the tv dont. some thime if i switch it off at the mains then back on then the tv comes on but not all the time. what can i do & can you help...
Good day!
Apr 20, 2011 | Televison & Video
A few weeks ago I got fed up with my router dropping off and having to unplug the power for a few seconds then plugging it back in. This usually took care of it until the weekend? A few weeks ago it...
try pluging the power adapter from the unit into a UPS power supply, The problem also not be the router, but an address issue with the one of the compoments connceting to the the router.
Oct 24, 2010 | Linksys Wireless-G WRT54G Router
Power supply, where can I get a power supply board.
if you know the compoment parts that need replacing yes if not order the whole replacment power bord from rca call there service parts number give them the tv model and they will be able to send you the entire replacment part
Jun 18, 2010 | RCA D52W19 52" Rear Projection Television
Power comes on only the akai logo does not appear only a light blue screen
Screen is at a certain source which views the compoment you connected
Sep 08, 2009 | Akai LCT3201AD 32 in. LCD Television
I purchased a Christie ds30 online. Plug it in and pushed switch...nothing happened! Popped the top and saw the fuse was missing...replaced with a smaller fuse to be safe....turned on projector and heard...
Um, regarding the projector power supply that went foo, yes there is a chance of fixing it, is it worth your time and money? Probably not. I would take it to a repair shop before ditching, but plan on purchasing a new unit. Replacing power supplies is possible, but on high-end electronics like projectors, I wouldn't personally reccommend it.
Dec 09, 2008 | Christie Replacement lamp Projector Lamp...
LG Studioworks 440SI 14" CRT Monitor Logo
67 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
