Question about Panasonic PT-50LC13 50" Rear Projection HDTV
PT40LC12 light just blinks green - just replaced bulb - no luck
Panasonic PT40LC12. Got a message that the bulb needed replacing, TV worked that night. Next night, just a blinking green light. Ordered a new bulb and it went in just fine but did not change the symptoms - $200!
  • 125 Answers
Do you have now a good picture or not
Posted on Nov 06, 2008
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
TV does not turn on, blinking green on off button.
that should be in the owners manual
techman
most sets havev a small door thathas has a screw on it and the bulb is inside a small cage you pull out
techman
May 14, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT40LC12 turns on and then shuts off after 15 seconds
Ballast Board it what turns Lamp on Call Encompass Parts Distr. or Look on their website.
Nov 21, 2009 | Panasonic PT-40LC12 40" Rear Projection...
TEMP or BULB light aren't on and Bulb isn't burnt out So whats causing the TV not to turn on
Probably the ballast if lamp is ok.If there is not even a standby light the the power supply.
Apr 25, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT40LC12 - Blinking green power light - no lamp fire up.
Had similar issue but had high resistance across leads. replaced with thermal fuse from RadioShack in the similar temp and everything works great. Info on the original part is on this link. http://www.willas-array.com/prod/products/directory/pdf/sefuse/FUSE_SMG.PDF Hope that helps. Chris
Apr 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
196 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
