Question about Epson Stylus R265 InkJet Photo Printer
Stop'd recognising CISS cartridge, just searches, won't print anymore
I did have USB disconnect during printing (laptop docking station) and now all I get after continuous searching for printer cartridges is the following message:-
"Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation".
This printer was originally Epson R265 with standard cartridge fit but, I had the CISS fitted at time of purchase 4mth ago and it's been working great until now!
How was it fixed (don't know)?
Systems personnel fixed it.
I'm only the end user!
Thx.
Posted on Nov 06, 2008
Epson SX210wont
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on
Open the cover of the product and remove the print cartridges
Close the cover and wait for the Insert Ink Cartridges message to display
Disconnect the power cord from the back of the product and wait for one minute
Reconnect the power cord. If the product does not automatically turn on, press the Power button
Open the cover and reinsert the print cartridges
Close the cover. If prompted, print a calibration page. Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us ForEpson Printer Support
Apr 01, 2014 | Epson Stylus Office Equipment & Supplies
HP LaserJet 1320 will not print
may be its problem *********** board. install another computer if you saw detect a new hardware so your printer is OK or no detect hardware devise then fault your printer mother board,replace it and buy a new mother board.
Best luck
xptareq2000
other help
xptareq2000@yahoo.com.
Nov 09, 2009 | HP LaserJet 1320 Printer
Im using ciss for my epson cx3700 and the magenta wont print anymore
Make sure there is not an airlock in the magenta ink line. This is best achieved by fitting a syringe to the flow line and sucking through some ink. Also you may be able to use a syringe and needle to inject some in into the cartridge to prime it. You may need to run several cleaning cycles to get the ink through - I had a similar issue with and Epson R300 using CISS and carried out over 10 cleaning cycles to get the yellow ink to flow again. It may also be worth removing the cartridge and leaning the exit area with a cotton bud soaked in isopropyl alcohol as residue can build up in this area. If the problem persists you can fill the cartridge with cartridge cleaning fluid to flush it through and then empty it and reconnect the CISS ink supply. If you disconnect the CISS Supply a good tip is to use a bulldog clip to prevent the ink from siphoning out of the supply line while you are attending to the cartridge.
Oct 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Red qoutation light keeps blinking/a440 print dock
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Office Equipment & Supplies
Hi! I have the Epson DX4850 All-in-one printer. I just purchased a Continuous ink system for it and tried to install it. I followed the installation manual very carefully and when I had finished installing...
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 25, 2008 | Epson Stylus DX4850 All-In-One InkJet...
Printer won't recognise new ink cartridges and correct itself.
Hi..
try to reset the machine.
disconnect the usb and power cable...and press and hold down the power button for 45 seconds and then reconnect all the cables and try again...
or try to clean the print heads...still does not work...could be an issue with print sensors..needs to be replaces.
Regards,
debroy
Nov 25, 2008 | Brother MFC-3240C All-In-One InkJet...
After docking laptop I have to add port prior to printing
I assume you're running Win Xp. Disconnect the USB cable from the docking station. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. Double click on the Konica icon. In the print queue that opens, delete any pending print jobs. Go to START/CONTROL PANEL/ADD REMOVE PROGRAMS. Uninstall any Konica software. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. On the MENU bar, click on PRINTER/SERVER PROPERTIES. Click on the DRIVERS tab. Remove anything that says Konica. Click on the PORTS tab. Remove ALL the Konica ports. Reboot Re-install the printer driver - DO NOT plug in the USB cable until it tells you to. That SHOULD do it. If it does not, please let me know and I'll research it further. Ed
Jul 13, 2007 | Konica Minolta PagePro 1350W Laser Printer
Epson Stylus R265 InkJet Photo Printer Logo
208 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
