Question about Nakamichi DVD-10S
Does not pick up DVDs
Cant get a solution. Since 3 years it has not worked. In the earlier period it would not pick up some DVDs and at other times it would pick up the same DVDs it had not picked up earlier. Eventually it stopped picking any DVD. What should i do?
0 characters
1 Points
My unit is a DVP3140, purchased 2006 or 2007. As soon as I got it, I changed the code to region 0 so that I could play the DVDs I bought when I lived in Italy. It worked great for about 3.5 years of...
By changing to Region 0 you've changed the Laser control and subsequently the Laser is failing earlier than it would have done under normal operation.
The only solution would be to replace the Laser which is not normally cost effective and often unavailable anyway.
CDs may still play for a period of time as these require less power as there isn't as much information to read as a DVD.
May 29, 2011 | Philips DVP3140
No disc error only for DVDs
This is problem laser unite replace it
Sep 05, 2009 | Sony DVP-NS575P DVD Player
My acurrian apd-3955 doesn't charge and play dvds
after 2 or 3 years of service the battery needs to be replaced.
Batteries have a finite charging "cycles". These cycles runs out every time you charge the battery.
Jul 28, 2009 | Radio Shack Accurian APD-3955
Bad disc message
Some times dust can collect on the laser lens of the pick-up assembly and cause this. If you can get to the lens, which is under the disc tray where the disc gets clamped and starts to spin, it can be cleaned with a q-tip and alcohol. Just be gentle with it. If this doesnt help the pick-up assembly will have to be replaced.
Jun 26, 2009 | DVD & Blu-Ray Players
Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
Cannot Play Commercially Produced DVDs (Panasonic DMR-ES40V)
Dear FixYa Team,
Thanks for your inquiry re my problem.
Since I posted, I THINK I may have solved my problem. I unplugged the unit for an hour or so, plugged it in again, and it DID play a "commercial" DVD that I had tried earlier. I don't know if this is a permanent solution -- we'll see. If not, I'll take the next step in seeking some help.
Thanks again.
Sep 13, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Won't play some DVDs
ya try cd lens cleaner ok they sell at store its a cd with litte brushes on it cleans lazor ok thx nick
Feb 11, 2008 | Mintek MDP-1010 Portable DVD Player
Dvd/vcr recorder/magnavox
my solution may be to never buy this companies products again as I have been having the same issue and since the machine is not been used much and since the disks worked before it really ticks me off. The suggestion noted to my issue recently really didn't seem to be valid due my above statted time period of no problems then sudden isses tends to show me poor quality of equipment by manufaturer.
Dec 06, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Dec 01, 2007 | LG DV276 Recorder
Nakamichi DVD-10S Logo
26 people viewed this question
Top Nakamichi DVD & Blu-Ray Players Experts
Are you a Nakamichi DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
