Question about Maytag MSD2454G Side by Side Refrigerator
Refrigerator Maytag MSD2454GRQ - Ice Dispenser Yoke
Hello, Bestdarngood:
I've received the ice enclosure (PS109031) and I'm ready to put everything back together. (I was able to disconnect the wire harness from the back wall without much difficulty). Now I could finish the job in a few minutes, except for the fact that I cannot get the ice dispenser yoke off the drive shaft of the auger drive motor. I need to do that so that the motor stays inside the enclosure and only the drive shaft shows through the hole on the enclosure. The dispenser yoke is then attached to the protruding shaft.
I have lubricated the shaft with WD-40 to see if the dispenser yoke can be unscrewed but to no avail. I have used robo grip pliers to hold the shaft in place, while I tried to unscrew the yoke, but still it wouldn't budge... Any suggestions?
If I cannot liberate the yoke, in order to save the motor, I can try to cut it out with a metal hacksaw, but it's not going to be easy because the dispenser yoke is made of heavy metal, maybe steel. (I hate to encounter this type of problem when everything was going so well). Appreciate your help.
lopezfra
  • 2 more comments
  • Francisco W. Lopez Nov 06, 2008
    Thank you very much for your help. Page 61 of the manual was very helpful because I learned that in order to remove the ice dispenser yoke I had to turn the yoke clockwise. This little detail is very important, because clockwise is the opposite to the way you usually unscrew anything. Holding the shaft with my robo-grip pliers and trying to move the yoke, however, still didn't do it. So I used a hammer and, after a few taps, the yoke was finally free. Immediately I attached the auger motor to the enclosure, connected the wires and put the yoke back on the shaft. I then connected the wire harness to the back wall and put the ice enclosure back in place.
    Now everything seems to be working fine, except that I'm getting crushed ice whether I press CRUSH or CUBE. The solution to this problem may be very simple, but I don't know it yet. Do you have any suggestion as to how to correct the problem? If you don't that's OK. It's a small problem that can wait for now. At this point I'm very happy to have being able to replace the ice enclosure successfully... Thanks again for all the help.
    lopezfra
    P.D. Member "mselloum" on 9/1/08 posted a question entitled Changing Ice Enclosure that hasn't been answered yet. He or she was wondering how to separate the yoke from the motor. Maybe my experience, especially in what refers to the use of a hammer in this task could be of help.
  • Francisco W. Lopez Nov 07, 2008
    OK. I will post a solution for Mselloum. Maybe I could be of help if he or she is still around and hasn't yet solved the problem. I saying this because it has been more than 2 months since the question was posted.
    Thank you, Bestdarngood. You too have a great day!
    lopezfra
  • andrewjsapp May 01, 2009
    Excellent Advice. I too was stuck on how to remove the yoke from the motor assembly. COUNTER CLOCKWISE and HAMMER are the two phrases that fixed it. I found it was easier to simply put light pressure on the armature (inside the magnet) than try to hold on to the shaft with a pair of robogrip pliers. Simply placing light pressure on the armature provided more than enough resistance to "tap" off the yoke. Thanks, you guys were so helpful.
  • Robert Sealschott Aug 01, 2012
    That worked Thanks. RLS
  • 3,037 Answers
I think this manual should be relevant to your fridge. Page 61 I think will give what you are looking for much better than I may be able to describe, let me know if it is still being a problem as I suspect the pressure that keeps the yoke on is what you are having problems with.
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Posted on Nov 06, 2008
  • Benjamin Patri
    Benjamin Patri Nov 06, 2008
    yeah, a lot of things have the reverse thread, glad to know that it worked out for you. Possibly you have a short somewhere or a bad connection with the ice coming out crushed. If you feel like helping that member, go for it. experience with these things is a great way to give back to the world.
    have a great day
We can not get the water to work
Posted on Aug 02, 2009
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
My Maytag Fridge Ice Dispenser stuck on crushed ice, so no whole cubes can dispense. What can I do?
If you look at the bottom out side area of the ice cube bucket/auger assembly, you will see a metal rod going front to back. That is the shift rod for cubes/crushed ice. Make sure it is free. Then look at the back of the refrigerator where the end of that rod goes into a square hole. There is a magnetic solenoid in that hole that shifts the rod for selection. The solenoid coil is either bad, unplugged, or for some reason stuck and not shifting that rod. That's where the problems is located.
Apr 12, 2015 | Maytag Refrigerators
My refrigerator is a Maytag MSD265hes, the ice maker doesn't make ice because the water doesn't go up to the freezer. It does goes to the door water dispenser .
read my tips on how to fix an ice maker not making ice problem;
http://www.fixya.com/support/r7602816-steps_when_ice_maker_not_making_ice
I hope it helps.
Good luck.
Jan 02, 2011 | Maytag MSD2756G Side by Side Refrigerator
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water button sticking
Replace that microswitch for the dispenser lever. It might not be a separate switch though, it may be part of the control board for the dispenser module. disconnect power to the fridge, remove the dispenser cover to expose the wiring, etc., determine what the lever actuates when depressed, and it will likely be the microswitch separate from the board.
Jul 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Changingthe ice enclosure
Hello, Msalloum:
I have the same Maytag refrigerator that you have and I faced the same problem with the ice enclosure. I have now replaced it. As to the problem of separating the yoke from the motor, you'll have to turn the yoke clockwise in order to liberate it. In my case, after holding the motor shaft with a pair of pliers, I had to tap the yoke with a hammer once or twice on a clockwise direction before the yoke became free.
In view that more than 2 months have elapsed since you posted the question, you probably have solved the problem long time ago. If you haven't, I hope you find this tip helpful.
lopezfra
Sep 01, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
800 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
