Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
Belt keeps breaking on my Ultra Vision Turbo Upright
Every time I go to vaccuum my carpet the belt immediately breaks. I have taken the roller off of the bottom and cleaned it all out. I am wondering if I need to try to clean it out better or if maybe I am putting the belt on incorrectly? I have gone through 4 belts within the week trying to get it to function properly.
  • 1 more comment
  • 4 birds Dec 10, 2008
    i try 3 belts already and 1st one work for few days and then broke but the other 2 broke right after i put them in and turn the vacuum ON.
  • Anonymous Dec 31, 2008
    same thing
  • Anonymous May 19, 2009
    same thing with mine and apparently a lot of other people as now I cannot even find a store that has the belt style #12 in stock. I am searching for the answer, if I get it, I will be back to post it. Until then, good luck!!
reddevil6
  • 1673 Answers
SOURCE: dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: electrolux upright vac
Belts can look ok, but after a short period stretch so they won't turn the brush roll under load, if you have never changed it, and if it is a flat belt, I would try a new one.
Posted on Feb 17, 2008
  • 120 Answers
SOURCE: dirt devil ultra vision turbo
remove the dirt cup, the top part should turn a little bit and then separate ( look were the clear plastic meets the colored top you might see a little picture of a lock and a open lock turn the lid towards the unlocked position , the filter should be in there
Posted on Sep 17, 2008
grandadfixer
  • 99 Answers
Get fixed under warranty if you do it yourself waranty is invaladated.
Posted on Oct 11, 2008
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
I have a upright vacuum model #U4269-930 I am trying to figure out how to replace the belt. I can't find a manual telling me how to.
UNPLUG THE VACUM CLEANER FROM THE ELECTRICAL OUTLET! OK, now you cannot sue me.
The plastic tabs on this machine can snap and break. Be gentle and try not to break anything.
Remove the roller guard on the bottom using a screwdriver where indicated to pry the retaining tabs.
Remove the upper shell of the motor housing using the same method on its retaining tabs.
Slide the belt off the motor shaft.
Remove the roller being sure to keep track of which way it came out so you can replace it in the right direction.
Remove the belt from the roller.
This is a good time to clean out the dust and debris especially from the roller and the motor's air vents (for cooling the motor).
Place the new belt on the roller.
Install roller in the correct direction.
Pry the new belt over the motor shaft. This will take some muscle and guts to stretch it.
Replace upper shell housing.
Replace roller guard.
Be ready to shut off immediately in case there is a problem.
Plug in and test.
Aug 19, 2010 | Hoover Vacuums
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Eats belts immediately
HI There,
Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
Hope this helped you,
Chris Jones
GoVacuum.com
May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
The belt keeps burning and breaking within 2 seconds of use
the rod should have a plastic runner wheel on it to hold the belt in place and reduce friction
Jun 07, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Why does the belt keep breaking as soon as I turn on the vacuum?
Hi Have you got the correct belt? If its breaking then the brush end caps or something is clogged. If you can get into the floor head ensure you look at the actual brush roll to see if there is anything is clogged or trapped. Remove all matter of dust and see if that works.
Mar 23, 2009 | Eureka 431A Optima Bagless Upright Vacuum
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Dirt Devil vacuum sucks... figuratively
Well, I guess your visitors have come and gone, but the vacuum remains the same. It sounds like you have a broken or worn belt. The belt should be changed once a year (approx) and can break if something is picked up that jams the brush. It is also possible that you have something obstructing the vacuum inlet at the brush housing.
If the belt is worn, it can still look o.k., but won't have the tension to turn the roller when it engages the carpet. I suspect the belt is your trouble.
Mar 21, 2008 | Vacuums
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
157 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
