Dell Motherboard
Problem for Dell (2336V) Motherboard
Case upgrade for Dell Dimension 4100
By bugster on Oct 11, 2006
I'm in the process of upgrading the case for a Dimension 4100 due to the original case being damaged. However, when I went to connect the new case's power button, led's etc. to the motherboard I found that Dell in their wisdom have neglected to mark the motherboard with what goes where.
Anybody have any idea about what terminals should be connected to what(power button, power led, hdd led etc.)?
Ta much
Best Solution
posted on Mar 02, 2007
Very Helpful)
Lightian
Rank: Apprentice
Rating: 100%, 1 votes
i upgraded a friends pc and had the same issue but i solved it very simply see go out and buy a new case but before you do look at the floor model look at the connectors now most cases come with a atx universal plug it's something new i noticed and i just plugged in the plug now depending on the style you might have to reposition ( key it to the terminals) the plug to get the proper sequence but rest assure it is not that difficult did it to a friends dell and it works perfect no problems what so ever give it a try
Was this helpful?
Yes
No
Solution #2
posted on Oct 11, 2006
Helpful)
sandrew
Rank: Wiz  Dell Expert
Rating: 83%, 5930 votes
The easiest thing to do it is look at your motherboard and make a note of the manufacturer and model/version number, as Dell don't make their own boards.
Go to the manufacturers web site and search for the manual probably in PDF format and download it and look for the relevent power button connections.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (2336V) Motherboard?
Answer
Answer
Dear All, Please help me about Mainboard MSI-7312 (have Slot AGP 1x) because Idon't know about VGA... (More)
Answer
hello, first of all I need know where the serial number for an iwill motherboard is usually located.... (More)
Answer
How do you install a performance chip on a 2003 audi a4 1.8t
Answer
heat trip switch melted
Answer
no audio driver. when i open my music there is a error found. said- bad directsound driver: bla bla... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14816
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
