Question about Sherwood Audio Players & Recorders
I have a Sherwood RX-2030R, 45 Watt receiver that will not tune to the lower AM stations. It tunes between 1320 and 1710 and will not even display the lower AM stations. The FM stations seem to tune correctly.
  • 3 more comments
  • JHobbleknock Nov 06, 2008
    I tried "resetting" the receiver by removing/unplugging the power cord as suggested. My problem still exists.
    I am aware of the "AM mode" button on the receiver, and yes, the receiver is capable of AM reception.
    I already have the receiver hooked to an external antenna. The problem still exists.
    I alread have the receiver hooked to an external antenna. The problem still exists.
  • JHobbleknock Nov 10, 2008
    My receiver used to receive these AM frequencies, so it's not an issue of the capabilities of the tuner. It used to receive the AM channels and now it does not.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to bring in the service
center near you! you can't repair that
b coz you will replaced the tuner board
for that?
Posted on Nov 06, 2008
  • 849 Answers
Try to connect with external antinea it may solve your problem
    Master:
  • 763 Answers
Look on the manual it should have a button to perform a AM mode. If it has then try to look also if your device is capable of AM mode and up frequency.
thank you for using fixya
CHARCOIS
  • 790 Answers
Hello!!
Try resetting once.. by removing all the internal chords and leave the unit for few min ..
  • 10,594 Answers
Check Sherwood RX-2030R specification of AM tuning frequencies limits in user manual.
Please confirm was it tune before below 1320 and above 1710 AM meter band?
Radio tuning
PIONEER VSX-D903S - A/V Receiver
PIONEER CU-VSX079 - Remote
Here's the basics: Make sure your receiver is in the Tuner mode, by selecting Tuner on either the remote (grey button), on the receiver, or from the GUI menu. (The display will also show TUNER.) There are a couple of different ways to tune a station. One method is with the remote. Use the Band button on the remote (or via the GUI display), or the FM/AM button on the receiver, to select the frequency type. Use the Freq/Ch buttons on the remote to tune, the number buttons for presets (30 presets total. Examples: Preset 5, simply press 5; Preset 15, enter 5-5; Preset 25, enter 5-5-5). You can also use the on-screen GUI menu and the remote to tune stations, using the lower grey buttons. If you want to tune directly, via the receiver, press Select, to switch between frequency tuning and presets (displays ST CALL) mode. Use the Multi-Jog dial to make your selection in either mode. The easiest way to program a station into a preset is to use the onscreen GUI menu. [NOTE: The GUI mode (TV Monitor Video Out, composite video) is active when an amber (orange) ring glows around the Multi-Jog dial (the GUI button on the receiver will also glow simultaneously). Use the remote lower grey buttons, or use the Multi-Jog dial and Select, to move the cursor and select commands on the TV. This A/V Receiver handles composite video/S-video, and Stereo/Dolby 3-Channel/Dolby Pro-Logic audio only. (Pre-ATSC/HD video, Pre-Dolby Digital/DTS multi-channel surround audio)]
Feb 07, 2014 | Pioneer VSX-D903S Receiver
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Lost all radio stations on my Sherwood RX4030R
It certainly sounds like the main tuner has failed, if IC301 does that function I would replace it and see what happens.
May 25, 2017 | Sherwood Audio Players & Recorders
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
Turner only selects odd numbered radio stations
this is the frequency settings that programmed in your audio system, reprogramming will be done your problem, if it cant be programmable install a device on antenna output(frequency modulator changer) you will pick-up all station you want but the problem is... the digital cant be set to appropriate radio station
Jul 22, 2010 | Yamaha RX-V663 Receiver
No sorround sound coming out of speakers out both left and right
I just repaired one for slow start .recapped the whole power supply board and now starts first go.I will check it out next week and post what I found
May 14, 2010 | Sherwood Audio Players & Recorders
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
1,065 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
