Question about Lexmark Office Equipment & Supplies
My printer will print 1 time then I get run time error
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Newer Lexmark printers require the .Net framework be installed for the software to function correctly. Verify requirements by the documentation or during the software install. If need be download the correct version .NET 2 (I believe) from Microsoft's website.
Posted on Nov 06, 2008
E07, e08, e02, e15 error in canon mp258, pl. give meaning of error & solution
Canon Pixma Mp258 Error Code and Possible Solution
P02 (Carriage error)
1.Make sure no foreign material stuck to the print head railway.
2.Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.P03 (Line feed error): an error in transmission line entering the line feed (LF) is a signal telling the printer to move to another line or a whole new line that would not otherwise have reached the end of the line.
1.Check wire print head position (timing **** disk film) on the side of the machine.
2.Check PCB logic board.
P05 (ASF sensor error) sensor for paper feed error.
1.Try to replace the following:
•ASF / PE sensor unit.
•Drive unit.
•PCB logic board.
P06 (Internal temperature error): caused by abnormal heat inside the printer.
P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full
1.Replace the wastepad inside the printer or install waste ink bin outside the printer
2.then Reset counter protection.
P08 (Print head temperature rise error): caused by thermal print head temperature exceeds a threshold.
1.Replace the new cartridge print head and / or change a new logic board.
P09 (EEPROM error): caused by corrupted or defective EEPROM chips of the printer.
1.Replace the logic board.
P15 (USB VBUS over current): caused by too much current, try removing the USB cable and then plugin again, if solve the error, try to replace with a new USB cable. If the error still exist replace the logic board.
P20 (Other hardware error): The failure of other hardware.
1.Try to replace the logic board.
P22 (Scanner error): a scanner malfunction.
1.try to change the scanner unit or change a the logic board.
E13 or E16: Ink has run out
1.Pressing the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
E04, E05, E14 or E15: Cartridge may not be installed properly
1.Reinstall the ink cartridge.
Jun 15, 2011 | Office Equipment & Supplies
I have a conon pixma mp198 error 27
ink absorber is full is canon error code E27. Try doing this steps to help you fix this problem.
Unplug the power cord then Press and hold down the Stop / Reset. After that Insert the power cable
and Press and hold down the power button (the button Stop / Reset fixed in press), When pressing the Power button, then release the button Stop / Reset. Press the Stop / Reset 2 times then release the Power button."Wait until the digit 0 appears in the display"
> Push down the Stop / Reset 1 time.
> Push down the Power button 1 time, the printer will print a sheet of paper.
> Press the Stop / Reset 2 times.
> Press the Power button 1 time, the printer will mecetak a sheet of paper
> Press the Stop / Reset 3 times.
> Press the Power button 1 time. (No printing)
> Press the Stop / Reset 4 times
> Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
> Turn on the printer.
> E27 error message is gone & the printer is running normally.
Nov 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Error code E27, ink absorber is full. Call service.
Follow these steps :
1. Unplug the power cord
2. Press and hold down the Stop / Reset.
3. Insert the power cable
4. Press and hold down the power button (the button Stop / Reset fixed in press)
5. When pressing the Power button, then release the button Stop / Reset.
6. Press the Stop / Reset 2 times then release the Power button.
7. Press the Stop / Reset 1 time.
8. Press the Power button 1 time, the printer will print a sheet of paper.
9. Press the Stop / Reset 2 times.
10. Press the Power button 1 time, the printer will mecetak a sheet of paper
11. Press the Stop / Reset 3 times.
12. Press the Power button 1 time. (No printing)
13. Press the Stop / Reset 4 times
14. Press the Power button 1 time rather long and loose (to turn off the printers).
15. Turn on the printer.
16. E27 error message is gone & the printer is running normally.
Oct 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
The Toner light flashes, it will not print .
Have you replaced the toner? By your post, it doesn't sound like it. Toner only lasts so long, it does run out, and then it's time to replace the cartridge. You can probably buy one from where ever you bought the printer, otherwise, Amazon.com is always a good place to buy things.
LINK to toners on Amazon.com
Dec 18, 2009 | Brother HL 1240 Printer
Pdf file too large: 1-2 pages about 1 MG.
Try and print the document 1 page at a time, upgrade the memory in the printer if you can, and most importantly; make sure that this is not a false error because the PDF requires postscript fonts to be installed you don't have installed on your printer. You can do this as follows.
Their are 3 standards for postscript, go to the manufacturers website and download the newest version of the postscript driver, not PCL. Many printers go nuts if running on an installed PCL driver and asked to print a PDF. If all else fails, this typically gives a lot of false errors.
Nov 08, 2009 | Brother MFC-8860DN All-In-One Laser...
Printer is ok but when i give the print command after some time it shows error which ''print error'' what is the problem
I'd like to have answers for some questions.
1) What interface do you use? Parallel or Serial
2) Does the printer run the self test? Switch on by holding LF/FF
3) Let me know the printer settings. You can find it by Switching on printer by holding FONT button. After it prints some data, press LF/FF. You will get the current settings of the printer.
Thank you!
Sabharish
Oct 13, 2009 | Epson LX-300 Matrix Printer
My x5470 won't print and error message says
Hi
Please do the following:
1) open the printer
2)remove the cartridge.
The problem is in scheme from printer that touches the cartridge from behind. You must clean this scheme from ink with a soft cloth dipped in spirit/kleannex.
Use the klennex/spirit and clean off those contact on the holder and printer will work again.
Then before you print anything, you should run cartridge alignment from control panel- printers and faxes-> right click on default printer-> properties-> printing prefrences(general tab) and also print a test page. Align the catridge and then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex/spirit on those holder contact panel
Please ask for further assistance and Do rate the solution as "FixYa" if you found it useful.
Thanks
Rylee
Mar 17, 2009 | Lexmark X5470 All-In-One InkJet Printer
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
HOOKING UP A PRINTER TO NETWORK USING PRINT SERVER
before running the PS Wizard in Vista, right-click on the icon for PS Wizard and select "run as administrator". This will clear the bind errors and wrong segment errors many times - this only applies to vista.
Jul 25, 2008 | IOGear GPSU21 Print Server
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
