Question about Maytag Dryers
MY MAYTAG NEPTUNE DOUBLE CABINET DRYER IS VERY HARD TO START. UPPER CAB WORKS FINE BUT LOWER IS AN ISSUE. ANY IDEAS?
5 Suggested Answers
SOURCE: Problem with upper cabinent of Maytag Drying Center.
Mine did same thing within warranty. There is a motherboard problem in them that is cause by power surge during an eletrical storm. First try unplugging for 10 minutes and see if it resets. If that doesn't work, you need to have the motherboard replaced that runs the unit.
Repair man took the front off my unit and replaced entire motherboard. He stated that it was a known issue with that motherboard. I have had no problems since my motherboard was replaced 18 months ago.
Posted on Mar 27, 2008
onthejob5130
  • 640 Answers
SOURCE: Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Posted on Jan 29, 2009
  • 686 Answers
SOURCE: Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Posted on Feb 23, 2009
protek480
  • 1714 Answers
SOURCE: How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
Posted on Aug 07, 2009
  • 254 Answers
SOURCE: Maytag Neptune dryer mdg40000bwq - no heat. how
if lil heat or takes a long time check ur venting.
if no heat on a gas dryer u must check the ignitor for any damages, the thermal fuse for continuity with a meter, and most have gas secondary coils which could be defective. those would prevent a gas dryer from heating.. hope this helps let me know whut u found
Posted on Feb 12, 2010
MAYTAG NEPTUNE DC MOD# MCE8000AYW
Your exhaust is gettting restricted and not able to remove the moisture from the clothes. Also check lint screen with very slow flow of water. If water rolls off wash filter good .. If water can't pass through smoothly then air is also having problem being pulled through as well.
Nov 15, 2016 | Maytag Dryers
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Magtag neptune mce8000ayq
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fggfs
Sep 22, 2009 | Maytag Neptune MCE8000AY Electric Dryer
My Neptune Dryer keeps giving message to "close door"
Call the repair number listed for your dryer and a technician will be able to come out and look at your dryer and identify the problem.
Jul 14, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dec 02, 2007 | Maytag Neptune MCE8000AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
