Question about Hyundai L90D+ 19" LCD Monitor
Entire image shifted
Entire image on monitor has shifted about 2 inches to the right on 1 inch up. I can't see the right side of the screen at all. Also, the image resolution resets itself to the minimum and cannot be changed. the image is also flickering slightly.
    Problem Solver:
  • 9 Answers
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Posted on Jun 08, 2009
Yesterdy i was working on an optical drive issue with a comp, got it done by removing an extra drive from this computer...but...the video on this computr is not wrkong now...what issue? what is the...
What is the Resolution
Refers to the sharpness and clarity of an image. The term is most often used to describe monitors, printers, and bit-mapped graphic images. In the case of dot-matrix and laser printers, the resolution indicates the number of dots per inch. For example, a 300-dpi (dots per inch) printer is one that is capable of printing 300 distinct dots in a line 1 inch long. This means it can print 90,000 dots per square inch.
For graphics monitors, the screen resolution signifies the number of dots (pixels) on the entire screen. For example, a 640-by-480 pixel screen is capable of displaying 640 distinct dots on each of 480 lines, or about 300,000 pixels. This translates into different dpi measurements depending on the size of the screen. For example, a 15-inch VGA monitor (640x480) displays about 50 dots per inch.
Printers, monitors, scanners, and other I/O devices are often classified as high resolution, medium resolution, or low resolution. The actual resolution ranges for each of these grades is constantly shifting as the technology improves.
Solution :
If you not get the proper video image in your screen that mean you have remove the driver of video, for installation the driver, put the Driver -CD in rom, and start the setup is simple set you get the driver.after installing the driver restart your PC
If you change any display setting then also you get the occur.for set the resolution go to the control panel and select the Display and go to setting tab set the ' Screen resolution" as before.
If you still not get the display then open you PC and remove the RAM and put again,and try again.
God Luck
Sep 15, 2011 | Asrock P4I45GV R5 Motherboard
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Jan 21, 2010 | LG Studioworks 775N 17" CRT Monitor
My screen is x X y inches. The windows page doesnt fit into it. There is one inch of black space on the monitor on the left and one inch of my windows screen is lost on the right!!!!!!!
With the on-screen controls, select Auto-Adjust. This should set suitable defaults based on the incoming signal. If you are using the VGA connector and the position still needs to be adjusted, use the on-screen controls to shift the displayed image to the proper location (under Display Settings -> Horizontal Position).
Apr 17, 2009 | Dell UltraSharp 1908WFP 19inch Black...
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Display is off-center
Try the Auto adjust button on the monitor buttons first.
If the entire picture of the computer is showing you can try to shift and stretch the picture through the menu button.
Sep 04, 2008 | E-Machines eMachines Monitor E15T4
2 inch black on both sides of the monitor (Horizontal)
Hi Bj, Is it an aftermarket video-card? If it is, like ATI or Nvidia, Download the recent drivers for your particular card, Uninstall your Videocard from device manager, then install the software.
Dec 10, 2007 | Dell Dimension 4600 PC Desktop
1 it is due to horizntal output trnansistor. 2 capacitor connected to horz output. 3 flyback transformer. hope this will help you.
Oct 08, 2007 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
Full Picture Display
It's definitely not convergence. Sounds like more of a problem in the horizontal section.
Dec 19, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
239 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
