Question about Sony PlayStation Portable (PSP) Console
Psp menu problem
Well, here's what happens when i start it up...
1. starts up fine for about 5-6 secs
2. A glitch in the screen appears ( like a tv with bad reception) then goes back to normal image
3. When i move to the categories (Game/Music Etc.) its very slow
4. Once i try to start a game/music/video, it freezes
This causes me to move quickly if i want to play a game. Although, once i actually get to START the game, it runs perfectly fine, like it used to.
If you or anyone can help, it would be greatly appreciated. Otherwise, ill just go back to the person who hacked it for me. Ok, thanks.
    Guru:
  • 134 Answers
Ok, your psp CPU clock speed is set to low speed.. 2 way to change:
1. If your psp has VSH menu enable.. : press "select" button, a small window will appear, otherwise its set to "disable".. See at "CPU CLOCK XMB" must set as "default". use left-right d-pad to change it. if vsh menu is disable you can try 2nd way.
2. Boot PSP under Recovery menu ( Hold R-trigger when turn on your psp ).. under M33 menu select "CPU Speed" then press "X", select "Speed in XMB" and "Speed in UMD" to setting as "Default" by pressing "X" button a few times.
Hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
http://e-arena.blogspot.com.
Posted on Nov 07, 2008
How to perform factory reset procedure pro1150hd
Factory Reset Procedure
1 With TV off/in standby....press home menu.
2 Within 3 sec turn TV on , Integrated Menu will appear.
3 Hold Display button until Final Setup appears in the top menu.
4 Arrow leftor right until yes appears in lower menu.
5 Hold enter until menu disappears.
6 Wait 1 min.
7 Power TV off and unplug from the wall for 5 or more min.
You can also try this:
Home Menu, select Picture, select "Reset", then ENTER, then select "Yes" and press ENTER.
May 09, 2014 | Televison & Video
Tip
Play psp games on tv via composite/component av cable
you will need to have:
1.a psp slim with custom firmware 3.80 or 3.90.
2.composite/component av cable.
3.installer plugin file FUSA that can be sourced in the internet e.g. qj.net.
4.memory stick pro duo with 2 gigabytes capacity.
steps:
1.source the FUSA installer file.
2.once sourced,extract it to your pc desktop using 'winrar'.
3.connect pc to psp via usb.
4.upon extraction,copy or drag all four files (prx and txt) to the 'seplugins' folder on the memory stick (ms0:/seplugins/).
5.if you don't have the 'seplugins' folder on the root of the memory stick,create it.
6.exit usb connection and completely turn off psp,then turn it back on while pressing the 'R' button to go to recovery menu.
7.on recovery menu,choose and click plugins,set the FUSA plugin to 'enable',then exit recovery menu.
8.you can also activate the plugin on the FUSA menu itself,and this is better recommended.
9.connect now psp to crt tv using component av cable.
10.load a game and after loading it,just right before clicking the 'start' button to begin play,exactly at this point,simultaneously press on the volume - and + buttons to bring out the FUSA menu.
11.after a few seconds,the FUSA menu will appear on the psp screen,change the settings accordingly,exit FUSA menu and start the game to play it on your tv.
*many games or emulators will work but not all as the FUSA file is still in its beta stage,you need to figure out which one will work or not through trial and error.use caution,this guide works but no guarantees.
*used a 2 gb memory stick pro duo as 4 gb didn't work.
*used on an interlace only tv and not progressive or crt/non-flat/lcd/plastma/hdtv's.
thanks.
on May 05, 2008 | Sony PlayStation Portable (PSP) Console
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
Pioneer SD-P50A5-K 50 inI
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
Nov 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Disc read error
ahh same happened to me. my ps2 was old (about 3 years) it worked fine untile i accidently dropped it on the floor. same happened on every game. but on movies, it only played the adverts and then stopped. So i went to a company and they fixed it.
Jun 27, 2008 | Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Feb 06, 2008 | Sony PlayStation Portable (PSP) Console
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Sticky Buttons
i need some help with this too, my psp is doing the same thing, can u please help me out too?
May 28, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
241 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
