Question about Motorola Radio Communications
MOTOROLA XTL 5000
WHAT IS "MAINTENANCE MODE"
"REMOTE DEVICE"
MEAN WHEN DISPLAYED
    Scholar:
  • 157 Answers
Hello BSEESTADT, The info displayed is telling you to "carry me to the radio shop". When did you buy the unit? Did you purchase a service warrenty? Call your local Motorola shop and ask for a technican not a manger or sales. He may do it for free or maybe a discounted service charge. If a charge is out of budget call some other radio service shops for cost. Good Luck
Posted on Nov 07, 2008
Motorola radio set XTL 5000 audio is not comming spk cables are ok. Main cct board is faulty.whst I do pl help me
Check that you have the radio set to message trunking. it sounds like your in transmission mode.
Nov 10, 2014 | Radio Communications
Help my hp laserjet 5000 printer is showing 50.4 fuser error
follow the following instructions
The Short Cut Method"
1. Turn the printer off.
2. Hold down the [Item-] and [Value-] keys.
3. Now turn the printer on.
4. Wait for RESET MAINTENANCE COUNT to be displayed and then release both keys.
NOTE: Some versions of the LaserJet 5000 will NOT have their maintenance count reset by following the preceding "short cut" method. This is due to the many different formatter board revisions. If the short cut method doesn't reset the maintenance count then you will need to go into Service Mode to manually reset the maintenance count.
Jul 30, 2014 | HP LaserJet 5000 Printer
Motorola XTL5000
Try to read it and write it again.
Dec 10, 2013 | Motorola Radio Communications
Have xtl 5000 says key failed but do not have key loaded
Mine says key failed, too, because it's expecting to find an encryption key, but there isn't one. I ignore it. I could make it go away either by flashing a key into it or else by unchecking the Secure Hardware Equipped check-box using the computer software for programming the radio.
Jul 10, 2013 | Motorola Astro Xtl 5000 M20urs9pw1an...
Sony Bravia stuck on Bravia screen
"Bravia Screen". Not sure what you mean. Is it in maintenance mode?
Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
DISPLAY - 5 - VOLUME + TV POWER.
When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
Hope this helps
Mar 10, 2013 | Televison & Video
05/94 error on 05 control head
This error message indicates an incorrect connection from main radio and your remote head, Check that you have installed correctly and that all plugs and fittings are snug and not loose.
Otherwise, the remote is cactus, that could be another issue, try without the remote and see if the radio works, the answer lies in either of those.
Hope this helps you.
Cheers,
Peter
Nov 01, 2012 | Motorola Astro Xtl5000 Model M20urs9pw1an...
Xtl head shows "maintenance mode" "remote device" is it not programmed? Also is control head wiring red 12 volt and yellow ign.?
The red wire on the remote head should go to the battery (with a fuse inline) the yellow wire should go to a switched 12 volt source (with a fuse).
The XTL radio is in need of correct programing, With out looking at the codeplug I would say that the option for remote head was not checked.
Hope this helps, Bill
Aug 22, 2009 | Motorola Radio Communications
I need codes for my cable box its a moterola cable box from shaw in winnipeg manitoba my name is justin ledoux could you send me some codes pleaz
Sorry it took so long to respond to your request for assistance.[Motorola... 5000, 5002, 5003, 5028] These are the listed codes for your remote control to use with a Motorola cable box. I hope this information solves your problem, of needing the codes to use with the remote control and you Motorola cable box. Thank you for using FixYa and have a nice day!
Feb 10, 2009 | RCA 3-Device Universal Remote with...
Part # for an XTL 5000 w-7 control head. H1517A or H1764?
H1517A is listed as a ASTRO SPARE CTRL UNIT W7 FAS. H1764 is listed as a W7 DUAL CONTROL HEAD RETROFIT KIT. You would need to call Motorola to confirm, but it appears one is the number used when you order it with a new radio. The other is the number you use when ordering for a radio you already own. It is unclear what the difference is. The H1764 is significantly higher in price.
Also, the dealers quoting you the W7 may be able to clear this up for you. The XTL5000 is an APB item and not in the standard dealer book.
Dec 26, 2008 | Motorola Radio Communications
Radio Communications Logo
2,283 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
