When i put the video into the combo,I can only hear sound but have no picture.I have tried a dry video head cleaner which has not worked.What can i do to make the picture visible?
CLEANING THE VIDEO HEADS - in the event of a head clog, the first thing professionals try to accomplish on a cleaning job is to restore the picture. Cleaning the video heads is the most critical part of the process. Use extreme caution. Never use cotton swabs. Cotton tends to grab, get caught or leave fibers in the heads. It can also break them. Using chamois sticks is by far the safest method. Soak a chamois stick with head cleaning fluid and place it directly on a video head with light pressure. For beginners, the safest method involves holding the chamois stick stationary in one hand and rotating the drum clockwise with the other. You want all scrubbing action to be in a horizontal direction. Never use any vertical motion; it's very risky for head tip breakage. When finished, allow a minute or two for the heads to dry and your ready to try it out. Pop in a tape and press PLAY. Confirm the picture is now clear. If not, you might want to repeat the above process once again. Ninety eight percent of the time, cleaning the video heads solves this symptom. Most of the remaining two percent is caused by a defective video head somewhere on the upper drum. Hope this helps Ps Dont forget to rate this.
It is a good possibility it could. and to answer your other question Look at this article I wrote for another site. http://www.techlore.com/article/14550/
Hi,Techman
Thankyou for your detailed response in helping with my problem.
I just had a few questions,as the machine is a combo,how would i get to the place where i need to clean?
Would a wet video cleaner do the same job?
Thanks.
