Question about Sharp Office Equipment & Supplies
There is a fault on the panel on my Sharp AR163 that flashed L and 4. Any thoughts ? Cameron
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Check and see what the other two codes are to pinpoint the problem
L4:
01:MAIN MOTOR FAILURE
02:DRUM DRIVE MOTOR PROBLEM
03:FUSER FAN PROBLEM
04:DEVELOPER MOTOR
06:TRANSFER BELT SEPERATOR MOTOR PROBLEM
11:SHIFT MOTOR
30:CONTROLLER FAN
31:PAPER EXIT FAN PROBLEM
Posted on Nov 06, 2008
I have a sharp LC-60LE832U TV. No picture. Symbol on bottom of screen flashes 5 short - then 2. Had a tech come out. He replaced (temporarily) the power supply board - did not fix. He said cannot be...
See if this helps:
http://www.tomsguide.com/forum/58779-4-sharp-power-button-flashing
"The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight."
"Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state."
Dec 04, 2015 | Sharp Televison & Video
Sharp AR163 copier RESET CODE ERROR FOR F2 — 04 solution
check the toner cartridge if third party replace with OEM
Dec 02, 2015 | Sharp Office Equipment & Supplies
Sharp AR163 copier CODE ERROR F2 — 04 solution
check the toner cartridge if 3rd party replace with OEM
Sharp AR163 CODE ERROR F2 — 04 solution
sir,
Check the toner cartridge if 3rd party replace with OEM
Sharp AR163 CODE ERROR F2 04 solution
replace toner cartridge if third party with oem
Why is my Sharp aquos tv arrow light flashing
This flashing light on the tv is actually a fault code. The 2 most common faults are blown capacitors on the p.c. board which would be visible with the rear cover off, (capacitors generally cost under $1 each) and a blown led which could be replaced but would require the know how. There are youtube videos on this repair but do not recommend this unless you have some electrical background and knowledge. Hope this helps.
Aug 17, 2014 | Sharp LC-46LE835U AQUOS 46 In. 1080p LED...
SHARP AR163 Displaying H2 error code
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
Sharp PHOTO COPIER MODEL No AR163
Sounds like a loose connector. "H" code on Sharps indicate a heater fault, if I remember correctly "2" indicates it's a thermistor.
So, if it was working before you took it apart, I'd be looking at the connectors, good luck & happy hunting....
Sep 09, 2008 | Sharp AR 163 Copier
Communication error
I assume this is a sharp??????????
U2 Backup memory problem
Aug 25, 2008 | Office Equipment & Supplies
That is a E prom error. You will have to reset it with code 16.Go into the simulation mode.Press clear,interrupt,0,interrupt.Then press 16 and start.You will okay after that if not  opps bigger problem.
Oct 23, 2007 | Office Equipment & Supplies
162 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
