Question about RIM BlackBerry Pearl 8100
No sound i have no sound i took the battery out still didnt work i did the default volume still didnt work what else can i do but speaker phone works
  • Anonymous Nov 09, 2008
    no sounds coming from the phone when I recieve emails or text messages, just the flashing light? how do i correct this?
Go into your profiles ( your speaker icon) and select advanced at the bottom of the list. A list comes up with all the different settings, and choose which one is not working for you, then you have to choose the subcategorie such as Facebook, texting, emails etc... then select each one if need be and change the "tone" it may be set to none, which was the case for me, then you can select how loud you want it and what type of ring tone you would like to associate with it, you can do that for every subcategorie if you wish!
I hope this was helpful, because taking you're bberry into the carrier isn't always easy for some,
Nathan
Posted on Nov 09, 2008
Take it into the carrier you have they should be able to fix it.
Posted on Nov 07, 2008
My phones audio is completely not working. The volume is set as high as it will go, but my alarms, texts, calls, etc have no sound. What happened to it?
didnt specify phone --generic answer --burnt out speaker ,damaged-audio circuit- need to have a tech diagnose the exact problem
Oct 24, 2016 | Cell Phones
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
No sound
i have a problem in my M4500 inspire speaker, 2 speakers are working properly but 2 are not working plz help meeeeeeeeee
Apr 19, 2012 | Audio Players & Recorders
Ringing volume
sound problem or volume right?,,,check the sound device or speaker of your mobile.. if the volume is active try to change it
Jun 26, 2010 | HTC Touch Cellular Phone
I took a vid from a4tech pk635m camera but there is no audio in the vid i took... how can i fix it????
Set your webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
May 06, 2010 | A4tech PK-635 Webcam
Sound won't work
make sure the webcam mic is set as default - especially importsnt if you have laptop with a built in mic as well
TEST SPEAKERS
Restart computer
Configure to your chat program
May 02, 2010 | Logitech QuickCam Communicate STX Personal...
Tv sound wont work
Make sure that all scarts and sockets are plugged in tightly. Try different inputs, try connecting a DVD player or another piece of equipment to the sockets in turn. Also, if you`ve got a sky box, remove the scart plugs one at a time and reconnect it immediately so that you know where you took it from. Check if there`s a switch on the back for external speakers, Make sure it`s switched to internal. Some of the TV`s have the switch for internal and external speakers in the menu`s. Make sure that any switches whether mechanical or electronic are switched to internal. Ian
Jul 24, 2009 | Philips Televison & Video
Ringer and speakerphone not working
a lot of the system volumes were put back to default. I only realized this when I downloaded the "Audio Manager Widget". Then I found that I apparently missed a couple volume settings.
also It might be due to the In-Call volume. The only time you can adjust the In-Call volume is when you're in a call (duh!). So, I called my voicemail and put it on speakerphone just left it all the way up and now I can hear the dialpad tones again!
also I think it was swapping from vibrate to full volume when I received an SMS (or was doing multiple things at once).
All sound stopped working on the device. It's an Dream from Optus.
try a quick reboot.. that shud fix all the problems though
if all the above moethod fails... its time to call the manufacturer....
good luck
Jul 08, 2009 | HTC G1
Volume on Cingular 8525
I'm having the exact same problem! I'm sorry, I have no answer. HOPEFULLY someone will answer this. IT SUCKS! It JUST happened, too. Maybe about a week ago or so. Hope you get yours fixed!
Aug 08, 2008 | Cingular Wireless Cingular 8525 Smartphone
Problem in my speaker........
goto CONTROL PANEL>Sounds & audio Devices(icon). goto VOLUME, far left menu option.Just under VOLME you should see a ICON of a speaker & the name of the audio device\driver. [If you don't u don't have a audio device INSTALLED] Make sure that the MUTE is not checked.,place a check ['place volume icon in the taskbar] ( that is the RIGHT bottom)On the left bottom of the same"volme" click "speaker volume" and raise the volume. GOTO >SOUNDS(sbmenu)>program events(windows>Asterick,Close Prgram,critical Battery Alarm,Critical Stop,Default Beep,etc,etc)
UNDER:: sounds, look & see if a sound is "taged", just to the right there is a "right" arrow that should be BLACK. When you touch the "arrow" the sound that u "taged" should sound.(1st) goto AUDIO >Default device: you HAVE to see some type of "audio device" e.i. Sound Blaster, Conexant AMC ,ABC Bananers,some type of audio device! If not, left click mouse DARK "arrow" down to see if you have some type of adio device\driver.If so chooze it.(2nd) goto VOLUME AND raise the volume.(3rd) Go back to "sounds" & while you click the dark arrow facing right, connect the speaker jack to the back of the "FEMALE" port.Sometimes they are not marked and you could connect to the wrong port.example: mike in instead of speaker out. understand!
Jul 18, 2008 | Audio Players & Recorders
RIM BlackBerry  Pearl  8100 Logo
171 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
