Question about Sharp 25L-S100 25" TV
Sharp tv on pure red
My tv keeps on pure red after replacing crt base.
  • voyet Nov 06, 2008
    hope you answer it
  • 3 Answers
First check all RGB drive if have a normal voltage and sync signal if normal maybe the picture tube have damage ,try to replace the new one. gud luck
Posted on Nov 06, 2008
"tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light"
Check the horizontal output transistor. Replace the same. Collector to base, or collector to emitter short to this transistor is a common case. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 23, 2013 | Sharp 21" Multi System Stereo TV
RCA 27V520T 27" TV has a red tint
Keep down the colour completley, and note whether you get a pure black and white picture. If not adjust the cutoff control, normally these are preset controls fitted on the base card of the TV; to adjust the excess colour seen on the screen to increase or decrease; so that you can get a clean black and white pocture with no tint on it. it is a time taking task; and should have some sort of skill and more patience. Sometimes you may have to retune other two cutof controls [Blue and Green], too to get the desired effect.
Oct 16, 2010 | RCA 27V520T 27" TV
Sharp tv 29" model#29l-fg1l. made from malaysia . the tv standy red light blinking from red to green when press on.nothing yes. what " s be ? please solve my problem?
Dear sir/Madam,
Check power supply(SMPS) section.Check/replace all electrolytic capacitor without power capacitor and resoldaring power supply section after then check horizontal output transistor.
thanking you
uttam
uttam_bm@yahoo.com
Sep 20, 2010 | Sharp Televison & Video
Green and red lines on tv
What kind of projection tv are we talking about a lamp based unit? or a CRT based one? If it is a lamp based one then you could have a dirty light engine which is expensive to replace. If it is a CRT based one you could have bad convergence IC or one of you tubes is in overdrive and the screen voltage needs to be adjusted.
Oct 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv blurred pics
Replace the CRT base/socket
Jun 17, 2008 | Sharp 25R-S100 25" TV
Please help me with my sharp t.v model no.21V-A300XB
The problem could be with the CRT base socket, why don't you try replacing that? It is not a costly component, and it is easy to replace. Make sure you buy the exact same thing and verify connections.
Jan 02, 2008 | Sharp 27C-240 27" TV
Rca 32 inch tv
your problem is in red video output circuit.
as you are seeing lines with red color
those lines are called retrace lines.
please check
  • supply to red video output ckt.&red video output transistor.
  • loose crt base or crt base connector.
  • componenrs related to red video output section
  • red signal coming to red video output ckt from signal processor.
  • at last but rare cases crt weak.
  • hopr this will help
good luck
Oct 17, 2007 | Televison & Video
Red screen!
your tv needs to be repaired.the color circuit.CRT or neck board could be defected.good luck.
May 18, 2007 | RCA F27615 27" TV
Red screen
Christ, why did you disturb the bias settings? Which stupid @#$% told you to that? The red color was most likely a blown Red Output Transistor, or something as simple as a bad CRT base. Now, I suggest that you switch off the TV, wait for a couple of hours, open the set, and very slowly and carefully pull the CRT PCB (along with sockets base. Then clean the CRT terminals (use a fine emery sheet.) Also check the base for dry (cold) solders. Replace the CRT board. Picture should be normal. If problem persits, then it is definitely the Red Output Transistor or associated components. Get a professional to have a look.
Aug 23, 2006 | RCA F27628 27" TV
Sharp 25L-S100 25" TV Logo
75 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
