Question about Holmes Products HQH307 Compact Heater
Cleaning behind front screen.
There is a significant amount of accumulated dust/hair behind the front screen, close to heating elements. The screen holes are too small to allow any cleaning tool to reach. This is a potential fire hazard.
Do you have a solution, other than disassembling the entire unit??
  • 108 Answers
Sorry my friend. You and I both know the answer to this. A complete disassembly and cleaning is needed. A fire hazard is a very serious event waiting to happen. Take care of this ASAP!
Ray
Posted on Nov 07, 2008
My electric fire place stopped heating although the fake flame comes on. There was also a burning smell when i turned it on. It's 2 years old
The burning smell may have been a result of the heating element being clogged with dust, dirt and/or pet hair. When this occurs the heating element overheats and automatically shuts OFF. Cleaning it may solve the problem. A vacuum with a hose and crevice too works well for cleaning it. Be sure to tunr the unit OFF & unplug it, before attempting any service on it.
Hope this helped you and thanks for choosing FixYa.
Sep 11, 2011 | Heating & Cooling
I put my electric fireplace on (not used for summer) it began to heat up - went clink and now the fan works but not the element. How do I repair or replace this pls?
Sara, it sounds like the heater's overheating switch turned the heating element OFF. This could be caused by a dirty heating element. As, they do collect dust, dirt, pet hair, etc. Cleaning it it (make sure the unit is turned OFF & unplugged) may solve the problem. A vacuum cleaner with a hose and crevice tool attachment works well to clean the heating element.
Hope this helps you and thanks for choosing FixYa..
Sep 08, 2011 | Heating & Cooling
It heats for a minute or two and then stops heating.
The heater overload switch is sensing an over heating problem and is turning the unit OFF. It may be as simple as a clogged heating element. Over time they do become clogged with dust, lint, pet hair, etc. This is because the air intake for the heating element is a floor level. So, whatever is floating in the household air gets sucked into the heating element when the fan is ON. Using a vacuum with a hose and brush attachment works well in cleaning the heater element. Be sure the unit is OFF & unplugged, before attempting this. You may be able to access the heating element thru the lower louvered door. Or consult your Owner's Manual regarding the cleaning of the unit.
I hope this helped you and thanks for choosing FixYa.
Jul 25, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
On my electralog heater, after about 5 minutes running the heat stops,fan is still running. Adjusting thermostat makes no change
From what you have described. it sound like the heating element is overheat and the automatic over heating sensor is shut it down. One of the primary reason these heaters overheat is that the become clogged with dust, lint & pet hair. Cleaning the heating element. may solve your problem. A vacuum cleaner (especially a Shop Vac) that has a hose, a brush attachment and a crevice tool, works well well in cleaning the heating element. Be sure the unit is OFF and unplugged, before attempting any cleaning.
Hope this helps you solve the problem.
May 19, 2011 | Dimplex Compact Electric Flame Stove...
I have a charmglo electric fireplace blower works but there is no heat is it the thermal cutoff and if it is what do I replace it with and also can it be put in backwards
More than likely it's the Thermal overload circuit or the heating element has given up the ghost.
As I just told one other questioner. These types of electric fireplace heaters were not designed to run for long periods of time. Their heat output is not much more than a blow drier. However, this is not just a problem with CharmGlo, it's with all the manufacturers.
Here's the problem ... The heaters work by taking in cool air, heating it and sending it back out via the blower. Over time, the heating element and/or blower become clogged with dust, lint and/or pet hair. This makes the heating element work harder and it over heats. Either burning out the heating element or the thermal overload switch or both.
You can try cleaning the heating element with a vacuum that has a hose and a brush attachment. While you're at it clean the blower fins and motor. Consult your Owners Manual to see how to access these parts, as they are under firebox, behind the metal grill on the bottom of the firebox, so to speak.
Feb 05, 2011 | Heating & Cooling
Electric dryer spins but is not drying
Heat box may have blown the thermal overload protector or heating element / wire is burnt out.
Common problem if dust / lint has accumulated in the dryer internally. May need to dismantal dryer front and remove tumbling drum to get to heat box (unit dependant).
Vaccum clean out all the lint and dust before working on replacing or repairing heat box.
embeytas
Jul 04, 2010 | Dryers
Works in the winter but not in the summer. Particles of dirt come in even though the outside vent is closed.
hello,
All Frigidaire Electric Gallery Series carry out same function when working it pull dust that are around can not be easily see with eye (micro dust) around throngh the air ventilation when it plug on to power .
what you are to do always after use is to clean it very well in other to avoid the accumulation of the dirt to avoid damage of element (HEAT PTOVIDER)hope this help.
thank you and thanks for using fixay.
Jun 24, 2010 | Frigidaire 30 in. Electric Gallery Series...
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
Holmes Products HQH307 Compact Heater Logo
188 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
