Question about Electrolux Kitchen Ranges
Hi I have an electrolux oven and grill the automatic switchc off for the oven went off and I do not know how to start it again,can you please help or tell me where to get help I have lost the booklet.Thanks Marie Dundas. Serial No 53912107 model no GXLOWNG
  • Malta0076 Nov 07, 2008
    Hi thanks for the suggestion but I am sorry the gas oven is a westinghouse model no GXL65OWNG seriel no 53912017 I left it on and the automatic swictoff button went off and I cant start it up again can someone help.Thanks
  • 728 Answers
Your automatic switch off button may be broken or have a short that will not allow the oven/grill to come back on. You will need to get that checked by a professional to get it repaired.
Posted on Nov 07, 2008
    Scholar:
  • 62 Answers
Hi, I will need you to double check the model number. I have searched various sites and data bases and cannot come up with this model #. Is this a range installed in your kitchen or is it an outside grill? I will continue searching for this model but Electrolux website says it doesn't have anything with that model
Posted on Nov 06, 2008
  • 749 Answers
Try this link for the manual
http://www.serviceforce.co.uk/pdfs/U24403.pdf
    President:
  • 624 Answers
Http://www.electroluxusa.com/node21.aspx
click the link above and you can get the support and help you need, just select the proper items from the menus on the webpage,
  • Dave DeGain
    Dave DeGain Nov 07, 2008
    Did you contact them thru my link?
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Electrolux Ovens
Where is the reset button
Hi.
thanks for request re your gas oven,unfortunately ,I have no experience of gas ovens, and am therefore unable to help solve your prob.
Check the experts, and see if there is one who is conversent with gas ovens.. Once again , sorry.
Jan 10, 2009 | Electrolux EOG7330WN Gas Double Oven
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Nov 17, 2008 | Electrolux EOB5610 Ultrafan Electric...
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Mar 01, 2008 | Electrolux EOB5630 Ultrafan Electric...
Kitchen Ranges Logo
149 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
