Dvd -player i got this dell dimension 4600i pc from a friend,i can't get the dvd player to work at all,the light comes on,and i can hear it humming but that's it!!i checked the cables inside,they are all hooked up good,it just won't play nothing at all!!!!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Download the appropriate driver for your operating system from http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=dimension+4100+drivers&rpp=12&p=1&subcat=dyd%2f1006%2f32&rf=all&nk=f&sort=K&ira=False&spf=Dimension&ssysid=DIM_PNT_P3C_4100&ssysn=4100&~srd=False&ipsys=False&advsrch=False&~ck=anav
If this drive did not come with the system, you will need to locate the appropriate driver for your operating system.
Posted on Nov 06, 2008
Previous fan failure
? I'm not sure what your question is, but replacing the fan on a dell dimension is pretty easy.
Here are the instructions: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm#1139391
And heres a link to buy one off of amazon: http://www.amazon.com/Dell-K0456-Assembly-Dimension-OptiPlex/dp/B000MME1TW
Dec 30, 2011 | Dell Dimension 4600 PC Desktop
Dimension 4600i---- cd/dvd drive not working(no sound of disc motion)---is a second cd or dvd drive the solution ?
First try a different power connection in the chassis, see if the drive is actually getting power. If no power indications with a different power molex connection, then most likely the drive has failed and you'll need a replacement. DVD-RW drives start at about $20 at places like newegg.com
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007589%20600003705&IsNodeId=1&name=IDE
Feb 12, 2011 | Dell DimensionTM 8400 PC Desktop
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 what kind of motherboard do i have.
Your Dell Dimension 4600 comes with an Intel motherboard with the Intel 865PE or 865G chipset running an Intel P4 class processor.
Here are the specifications for your machine and motherboard:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
Mar 07, 2010 | Dell Dimension 4600 PC Desktop
How do i open my Dell dimensions 4600 to install
Just lay it over on its right hand side, there a button on the top and the bottom, press these both at once and lift. It will just hinge up and give you plenty of access. When closing just make sure its lined up and it simply clicks back into place. Cheers from Scott
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
On the outside of a Dell desktop, where are the slots for the D and E drives ?
Below is a link to the users manual on the dell web site. It shows how to open the case and access the DVD drive area and replace or install a second DVD. You will need a med size phillips head screwdriver, perhaps a med size standard screwdriver to help depress tabs etc. It's a pretty straight forward job just make sure you disconnect all devices from the box, and unplug it to avoid static shock.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm
Nov 10, 2009 | Dell Dimension 4600 PC Desktop
I nned to find out how to buy an ethernet adaptor for a Dell Dimension Desktop. It is 383 MB RAM and 32 bit File System. thanks
You can buy a pci ethernet card and put it in a free pci slot. Install the driver and it should work.
Dec 02, 2008 | Dell Dimension 4600 PC Desktop
This dell 4600i does not recognize anything i plug into it
First you need to check that you have usb activated in bios.....mostly its F10 at start up or DEL key to enter bios verify that it has been activated
go to device manager and check if it has any ? ! on any of the usb devices
keep me posted
Cheers
Nov 14, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
