Question about Kenwood KDC-CX87 10-Disc CD Changer
Need mechnical layout of cx-87
I took it apart to insert the loose cd cartridges inside the changer, now i can't figure out how the angle adjusters go back in, any help would be appreciated, thanks reza
0 characters
1 Points
My CD player is reading "No Disc"
The laser has most likely failed or needs to be adjusted. If you cannot take it out and take it apart, and use small tools and a meter, replace it or have it professionally done.
Jun 09, 2014 | CD Changer Player 2000 Jaguar XK8
I need a wiring diagram on how to configure a new harness for my panasonic DP 801 8 DISC CD CHANGER....MODEL CX-DP 801 EN
All parts and service manuals can be obtained by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Aug 04, 2013 | Panasonic CX-DP801 8-Disc CD Changer
I would like to advise that it would be better for you to update to a universal type adapter that can be easily fitted to your Player. This adapter would be able to play from memory sticks, usb memory or even your Ipod and that means all your MP3 can be easily stored and carried over. The DVD changer is compatible. However I hope you will decide with my advice and check for the models available in your city. So go with the times. Good day
Aug 02, 2010 | Panasonic CX-DP801 8-Disc CD Changer
Cartridge will not reject CD discs
i had this when i got one off ebay, take it apart (cover) usually 6 screws, the cartridge inserts may not be aligned inside (part cd sits in) if that is the case you need to remove it/them. it tokk me 40 mins of carefull prise and pull
Jul 01, 2010 | Kenwood KDC-C719 10-Disc CD Changer
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car CD Changers
Cant remove magazin with cds without changer is on power
Is there a pin-hole on the front of the cassette? If so, insert a paper clip into the hole to manually release the cassette.
Sep 08, 2009 | Panasonic CX-DP88 8-Disc CD Changer
Missing cartridge
I know it has been a year but did you ever find that cartridge?
Feb 20, 2009 | Panasonic CX-DP801 8-Disc CD Changer
Mecha error
This indicates a mechanical error... ie: the cd is jammed, the drive mechanism has become seized, if this a multiple CD changer, it's possible the CDs in the cartridge were inserted on a slight angle and the drive mechanism can't work with that.
If you're mechanically apt, consider removing the cover of the CD changer and releasing the mechanism by hand. If the unit is still under warantee or if you're not comfortable doing these things, repair might be your best option.
Mar 14, 2008 | Car CD Changers
If this is a cd changer then there is a reset button inside door or on changer some where that you press and hold and it should reset system. If not then unplug from power for atleast 15min. Re-enstall
Oct 04, 2007 | Sony CDX-646 10-Disc CD Changer
Kenwood KDC-CX87 10-Disc CD Changer Logo
23 people viewed this question
Top Kenwood Car CD Changers Experts
Colin Stickland
Colin Stickland
xxxxxx xxx
Are you a Kenwood Car CD Changer Expert? Answer questions, earn points and help others
