Question about Canon PIXMA MP470 All-in-One Printer
Cannon MP 470 printer not printing whole document
My printer stops about 1/3 of the way done on most documents. Same place, different documents. Installed new drivers 3 times. May work for a while but then back to it. Cables are good. Just some BS generic error after it times out. My old computer with XP did not do this. I have a newer one with XP and it does it.
Thanks for any suggestions.
    Problem Solver:
  • 6 Answers
Hi..
Try to reinstalling you OS (do not use repair if u use win XP, make a fresh copy), some viruses can affect document like this.
Thanks
Posted on Nov 06, 2008
How do you scan from canon mx340? I have pressed the scan button and publisher automatically activates from my pc but that's it
1. Install the MP Navigator EX software located on the disc that came with the printer.
2. Go to Start > Programs > Canon Utilities > MP Navigator EX > MP Navigator EX.
3. Select Photos/Documents or Stack of Documents.
4. If Photos/Documents was selected, open the top of the scanner and place the document you wish to scan on the glass with the top facing to the left. If Stack of Documents was selected, flip the plastic tray open on the top of the printer and place the stack of papers in the tray.
5. Select the Document Type in the left pane, then click the Scan button.
6. The scanning process should start. When it's finished, select Save to save the document(s) as a JPEG, or select Save as PDF to save it in PDF format.
LLCOOLRYAN
Nov 22, 2010 | Canon PIXMA MX340 Wireless Office...
My Cannon Pixma MP500 multi-function printer randomly scans only part of the document on the glass. Sometimes it does get it right; that is it correctly scans the whole page, but very often, the scan...
Try to adjust the scanner resolution
Solution: Adjusting Output (Scan) Resolution (Windows) - MP150 / MP170 / MP450 / MP500 / MP800 / MP950
Adjusting Output (Scan) Resolution By changing the resolution, you can set how clear the image is going to be.
The higher the resolution, the clearer (but the larger) the scanned image is.
The resolution can be changed before scanning. (Note)
If the resolution is doubled, the image data will be quadrupled.
If the data is large, problems such as slow processing speed or lack of memory may occur.
To change standard scan settings using MP Navigator, click here
To change more advanced scan settings using the scanner driver, click here
Using MP Navigator
  1. Place the document face-down on the platen glass.
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    Display varies according to the printer model.
  4. When the Scan Photo/Document window is displayed, click 'Specify'.
  5. When the Scan Settings window is displayed, select the resolution in Scanning Resolution drop-down.
    Select from the following scanning resolutions:
    [Text(OCR)]: 300/400/600
    Other: 75/100/150/200/300/400/600
  6. If necessary, set other items as well.
  7. Click 'OK'.
  8. In the Scan Photo/Document window, click 'Scan' to start scanning.
Using the scanner driver
  1. Launch MP Navigator.
  2. Click 'Scan with Scanner Driver'.
  3. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
    To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
  4. In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning.
Aug 13, 2008 | Canon Office Equipment & Supplies
I have a cannon MP 160 printer/scanner. It does not work on a Mac
Uninstall all your drivers (and delete the preferences) and download the Mac drivers from this link. The drivers that came with your printer were developed before Snow Leopard came out.
Jan 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I just received a fax on my Cannon Mx310 but I
mailcenter12 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Error Message on PIXMA 470
try to reset your printer--
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
Mar 09, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
I have a printer MP 470 cannon, but I want to be able to scan documents but cant. What do I need to do?
You must have the Canon program "Scangear" (which is a twain driver) installed. Then follow the instructions on page 31 of the MP470 series Quick Start Guide. The guide can be found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403#DownloadDetailAct
Nov 11, 2008 | Cannon Office Equipment & Supplies
Trying to clear memory to stop printing on my cx5200
You can cancel the documents you sent to the printer by cancelling the print job from printers and faxes window, right click on printer icon and on dropdown select or click on cancel all documents.
Apr 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Canon PIXMA MP470 All-in-One Printer Logo
69 people viewed this question
old marine
old marine
