No spysweeper icon displayed on my taskbar - Computers & Internet
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
To uninstall Spy Sweeper (if you used the UCSF install) locate a file named SSECleanup.exe in the <RootDrive>\Program Files\SpySweeper Install\ directory. ou can search your hard disk for this file.
After which, reinstall the product.
Posted on Nov 06, 2008
  • Daniel Bates Nov 06, 2008
    Try opening Spy Sweeper from the Start Menu, then open the options to determine if the icon is disabled.
How Do I Safely Remove Hardware
First off, some of those icons will never be removed, as they are necessary to be there for verification purposes. Safely Remove Hardware is one of them. Any time you plug in a device such as a flash card or external hard drive, devices that read and write data, they show up in this block. Since Windows does delayed writes to save time,l if you simply unplug these devices without letting Windows close out the write cache may cause corrupted files. Right clicking on the Safely Remove Hardware icon will cause a listing of attached devices to be displayed. Clicking on the device you want to remove (unplug) will tell Windows to close out the file cache and dismount the device. Windows will do this and them notify you that the device is safe to remove.
Now, regarding all those other icons that appear,such as OneDrive, volume control, and others, if you don't want them showing up in the taskbar, you can right click on the "^" caret symbol that expands the taskbar, then choose SETTINGS. This will bring up the taskbar settings menu. Scroll down the page to where is says "Select which icons appear on the taskbar" and select that. You will see a long list of possible taskbar icons. Turn off the ones you don't want to see display on the taskbar. This does not remove them from the system, but they will no longer display on the taskbar,
Aug 15, 2016 | Computers & Internet
Tip
Hacking Your Way Through the Interface
Use Registry hacks to make a grab-bag of great interface changes.
Hidden in the mazes of the Registry are countless ways to hack XP's interface. Here are some of my favorites.
Hide All Icons in the Notification Area
The System Tray, also called the Notification Area, is the small area on the far-right side of the Taskbar, in which utilities and programs that run in the background, such as antivirus software, show their icons.
I don't find it a particularly intelligent use of screen real estate, so I'd prefer not to see the icons there. To hide them, run the Registry Editor [Hack #68] and go to HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer. Among other things, this key controls the display of objects throughout XP. Create a new DWORD called NoTrayItemsDisplay. Assign it a value of 1. (A value of 0 will keep the icons displayed.) Exit the Registry and reboot.
While you're at the HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer key, you can also delete the My Recent Documents icon on the Start menu. Create a new DWORD called NoRecentDocsMenu. Assign it a value of 1. (A value of 0 will keep the icon displayed.) Exit the Registry and reboot.
Hide Only Certain Icons in the Notification Area
You might like to display some icons in the notification area but hide others. If so, you can hide icons on a case-by-case basis. You'll do it by delving through menus, though, not by hacking the Registry. Right-click on the Taskbar and choose Properties → Taskbar. The Taskbar and Start Menu Properties dialog box appears. This dialog box, as the name implies, lets you control how the Taskbar and Start Menu look and function.
In the Notification area of the dialog box, check the box next to "Hide inactive icons," then click Customize. The Customize Notifications dialog box appears,
Click on the program's listing in the Behavior column, and choose from the drop-down menu to hide the icon when the program is inactive, always hide it, or never hide it. Click OK twice. Your changes will take immediate effect.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
Sound not comeing at the takbar speak not show
Show the volume icon in the taskbarIf you end up finding to impractical notification area to have the speaker icon displayed inside the taskbar, you can tell Windows 7 to resume showing the volume, same steps as before:
  • Click on the start menu, and type "volume"
  • Select the Volume's dropdown menu, and change its value from "Off" back to "On"
  • Click OK to confirm and close the Control Panel
Windows 7 has now resumed displaying the volume icon in the taskbar!
Else IF windows XP
goto control panel click sound and audio device then check Place volume icon in the taskbar.
Aug 15, 2011 | Computers & Internet
How can i return my volume icon in my taskbar...
By default, the Volume icon is not displayed when you initially install Windows XP on your system. To Display The Volume Icon follow the steps given below: -
1. Click Start, and then click Control Panel.
2. Double-click Sounds and Audio Devices.
3. Click Show volume control on the taskbar.
4. Click OK.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 13, 2010 | Computers & Internet
Unable to display battery charge on taskbar
Select power management from control panel. there u will be able to turn it on.
Cheers.
Sep 05, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Volume control icon not displayed
where the clock is RIGHT click and select CUSTOMISE NOTIFICATION ICONS then make sure that the the volume panel is showing this - hope this helps.d8a766d.png
Aug 11, 2009 | Microsoft Windows Vista Home Premium...
Icons and everything displayed sideways
If you're referring to the taskbar that's usually on the bottom of the desktop, click on the taskbar and drag it to the bottom. Then right click on the taskbar and check "Lock the taskbar". This should solve your problem. All the best.
Greg
Jun 23, 2009 | NEC MultiSync 77F 17 in.CRT Conventional...
Updated webroot
faulty installation - right click icon by clock on taskbar and shut program down. then go into start menu - webroot - webroot - uninstall. after pc reboots, download latest product version from webroot's website.
Sep 10, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Our spysweeper icon is gone in lower right hand corner of computer. opening windows desktop on lower left corner i cant find it. our code is ssfc-sbpe-aadh-cvir-kygi
Don't post your key on here.
As for your icon, go to Start > All Programs > Webroot Spysweeper > click on the Spysweeper program and drag it onto your desktop.
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
