Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Wireing three units together
I would like to know if I wired my new heaters correctly went form power supply 20amp breaker 12/2 wire to thermostat from thermostat to first heater black and red wire pigtailed a second wire and ran it to the second heater pigtailed black and red with a second wire to the third heater. also hooked up ground wires in each of the units. Have I correctly wired these units together
    Scholar:
  • 147 Answers
Yes, you did a good job. Sounds like you paralled them. Which is right buuuut what size are these heaters. Add the wattage of all of the heaters and divide by 120 and that is how much current you will be using. On a 20 amp breaker you can only pull 16 amps safely. I think you will be way over unless the heaters are 600 watts each. You are allowed 1800 watts on a 20 amp circuit.
Posted on Nov 06, 2008
  • butch welch Nov 06, 2008
    Doesnt matter if the voltage is 120 or 240 you are only allowed 16 amps on a 20 amp circuit. just let me know the wattage of the heaters. On a 240 volt circuit you are allowed 3800 watts.You might be in good shape.
We want to buy a Neff bu-in double oven which needs a 20 amp supply (hard-wired).Our old existing oven is running on a 30 amp supply apparently. Will we have problems when the new Neff is fitted?
The breaker could be changed from 30a to 20a. A 30amp breaker will run the unit but you will have less/no protection since the oven will pull 10 extra amps before it trips which could totally fry your oven depending on the failure.
Re-check the wording to see if it says 'minimum' 20amp breaker or if it indicates 20amp breaker only. If it's minimum 20amp I'd run it.
If it says 20amp only, I'd change the breaker. The existing wiring and outlet will be OK, if the plug-in is the same.
Get an electrician to change the breaker. You should really know what you are doing before you try it yourself.
Sep 16, 2017 | Neff Ovens
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
I have ran my 12-2 wire from breaker box to thermostat from the thermastat i ran a 12-2 wire to first heat. question 1) do i run another 12-2 wire from heat 1 to the next heater i want on this thermostat?...
There are so many questions. WHAT IS THE MODEL number of the unit that you are wiring The thermostat and the source voltage are two different things. What voltage are you wiring this to?
Apr 30, 2017 | Marley Electric Hydronic Baseboard Heater,...
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
I have a Dimplex in wall heater model 690221900 120 volt 1500 watt. Their is a 110 volt feed line (black, white and ground wire)coming in to the heater housing as well their is a two wire thermostat...
Well, for your wiring, there's nothing wrong with it, So, I think there's two way to find out which ones is wrong, first:
Install your heater without thermostat first, is it working, does the breaker blowing!!!.
If No, then your thermostat is the cause, but if Yes, then,
second:
Try install it with the new breaker with 10 A minimum, you must replace the breaker with new ones.When it's OK, then try install the thermostat too.
Hope it works!!!
Dec 09, 2009 | Sewing Machines
Not sure hooked up correctly
The black and white wires should both go to the breaker. Not just the black wire. If you hook only the black wire to the breaker then you are only feeding the unit with 110 instead of 220. Both wires need to be hot.
Jan 20, 2009 | Fahrenheat Electric Convector Baseboard...
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
137 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
