Question about Philips GoGear SA5285/37 Digital Media Player
S.O.S My SA5285 can't connect to my computer although I set up CD Driver. And where's battery? My battery can't charge and it can't turn on. Please help me. Thank you so much
  • Anonymous Jan 23, 2009
    I have plugged my SA5285 in and it seems not to be charging correctly. I've had it in for 2 days and it's on low, still.
  • 8,596 Answers
Make sure the hold/lock switch is not engaged.
Try a different uSB port on your computer.
Posted on Mar 18, 2009
My linx 8 is not turning on. It is charging as the red light is on when plugged into charger. It feels quite hot. Please can you help? Many thanks
Sounds like a Bad battery, or connection point not allowing battery to charge? although if the battery is getting hot it's probably charging just a bad battery. ...
Feb 26, 2015 | Health & Beauty
I cannot get my camera to turn on
Before you can download pictures to your computer, you have to install the software that came with the camera. On older operating systems, on the CD will be the driver you need, so the OS recognises what you are connecting to the USB connector. From Windows 7 and up, the driver will be in the OS and the computer will recognise the camera, after you with it on. But be aware as long as the USB cable is in the camera, you won't see a thing on the camera. Lots of camera's ar also charged through the USB connector, so unless the camera gets a signal you are connected to the computer, it won't start communicating, so it looks like nothing is connected.
If the camera won't turn on, after you pulled out the usb cable (from the camera) please first charge the battery first.
Then try again.
Sep 20, 2014 | Kodak Cameras
Battery exhausted message no battery charged
The manual says:
Confirm all connections.
Off is selected for Charge by computer in the setup menu.
When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So be sure you are charging the correct way. Best way to do is to remove the battery and put it on the charger for a couple of hours. If you have the battery out, you can check all connections of battery and in the camera.
In trouble shooting, more than a full page is dedicated only to the battery and the method of charging. The manual is still online, but should also on the CD you got with the camera.
Nov 16, 2013 | Nikon Coolpix 3200 Digital Camera
Hi. I have a Philips SA5285 8GB mp3 player 3 months. Yesterday, whilst i was charging it via laptop, I unplugged it and switched it on to listen. When it turned on its said (Wait For USB Connection?) So...
You can reset your player by gently inserting a pen tip or other sharp object into the RESET hole on the side of your player. After pressing the reset button, power on the player. If the player is still unresponsive, charge your player for a minimum of 30 minutes before reattempting a hard reset and then power on the player. NOTE: If a removable battery is used for your player, just remove the battery from the compartment and then insert it again.
Step 2. Upgrade the player
If the resetting does not work, connect your player to the PC and perform Upgrade function by using Device Manager. To download the Device Manager, you can visit Software & drivers section at >> www.p4c.philips.com > Here is a manual >>
Mar 09, 2011 | Philips GoGear SA5285/37 Digital Media...
My mp3 won't turn on is it broken?
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GoGear SA5285/37 Digital Media...
The battery will not charge
You have to try using another battery to see if the battery is the problem. If same problem occurs even you try another battery, then there's a loose wire connection inside and needs to be soldered.
Have a gret day!
Sep 20, 2009 | Philips GoGear SA5285/37 Digital Media...
Sa5285
Yeah - go into the Settings menu and turn the screensaver to OFF
Jan 20, 2009 | Philips GoGear SA5285/37 Digital Media...
Zen shuts off after only playing a few songs
How long have you been doing this for (months)? You may have already drastically reduced the life of your battery
Battery
& Charging
The Zen’s battery:
The Zen uses a 3.7v rated Lithium-Ion rechargeable battery. A 3.7v rated Lithium-ion battery actually gets charged to around 4.2v with a tolerance of +/- .05v. A charge of 3.7v/3.8v is actually about a 50% SoC. At 3.3v, lithium-ion batteries have typically only utilized 70% of its 100% charge capacity.
Charging Voltage = 4.2v (4.1v)
Nominal Open-Circuit Voltage = 3.7v (3.6v)
A note on Over-Discharging and Over-Charging:
In general, Lithium-Ion batteries do not like to be overcharged (usually above 4.2v) or excessively discharged (under 2.5v-3.0v). If a Lith-ion battery falls below 1.5v, then typically you shouldn't try to recharge it at all for "safety" concerns. A fully discharged lithium-ion battery causes the formation of copper shunt in the cell which begins to get extremely hot when attempting to recharge. A lithium-ion battery should not be charged above 4.3 volts. Above 4.3 volts and the cell causes lithium metal plating on the anode. The cathode material becomes an oxidizing agent and loses stability and begins releases oxygen. This can cause the battery to heat up. Lithium-ion cells should never get above 130°C (265°F). At 150°C (302°F) the cell becomes thermally unstable and can eventually lead to a thermal runaway. These are the safety reasons why the low and high voltage cut-off and temperature sensing circuits are used. If the internal temperature of the battery gets to high, the temperature sensing circuit can initiate a mechanical pressure switch that will permanently cut-off the current path and prevent anymore charging.
How do you charge the Zen (Battery)?
It can be charged by connecting it to a USB port on a computer or by using an AC Wall Charger within the Zen's charging specs (see below).
Can I use my cell phone's AC Charger to charge my Zen?
I believe the max input voltage of the Zen is around 5v. Most devices that can charge or run off the USB host power can handle the max 5v of USB ports. 4.2 volts is usually the max Lithium ion batteries are charged to. It is usually around when the high voltage circuit is triggered and stops the charging of the battery. I would not connect a charger to the Zen that puts out more volts then 5v with an output current beyond 2400mA (2.4A) to be safe.
When and how often to charge?
To be safe, I would avoid frequent full discharges because this puts additional strain on the battery and usually shortens its life. Partial discharges with frequent recharges are better than one deep one. Recharging a partially charged lithium-ion does not cause harm because there is no "memory effect" like with older type Ni-Cd (nickel-cadmium) batteries.
Do I need to charge the Zen for hours before I use it for the first time?
With Lith-Ion batteries, the first charge isn't any different then any other charge. There is no technical need to fully charge it the first time you get it other then the fact of being able to use it longer since it will have a full charge. They are not like other types of previously used rechargeable batteries that needed the full charge at first. Most likely by the time you get everything all figured out and loaded onto the device, the battery would be fully charged anyway.
Please note: I do recommend that you at least connect the Zen to a computer while it has sufficient charge on the battery in order to properly be detected and have its devices drivers load properly. In other words, don't use your new Zen for a period of time to where you drain enough power from the battery to just come on and turn off automatically or to the point the Zen doesn't come on at all. If you do, then you may have detection and charging issues when you go to connect the Zen to the computer.
How long will the battery in the Zen last?
Lithium-Ion batteries have a life span of about 300-500 discharge/charge cycles or 2-3 years from being manufactured.
Storing or not using the Zen for long periods of time:
Lithium-ion batteries (by themselves) with no built-in voltage monitoring circuit have a really low self-discharge rate (1-2% a month) when not being used. Having the addition of voltage monitoring circuits will slightly increase the discharge rate, but should not reach the point of excessively discharging the battery to where it won't turn back on unless sitting unused for an extended period of time and if its last state before powering off was a already in a low voltage state. So, as long as you aren't storing it for long periods of time at a low discharged voltage, the battery should be ok to recharge.
Accidently left the Zen plugged into the Computer all night or for a long period of time:
I wouldn’t make a habit of doing so. Long term usage like that could shorten the life of the battery. Although you may be fine for a while, leaving it plugged in occasionally all day and night, most likely won't hurt it, but leaving it plugged in every day and night may not be a good idea. Although once it is charged to 100%, the battery's internal high voltage cut-off circuit should keep the battery from over-charging and the devices charging circuit should keep applying a trickle charge when detected a drop in charge below full. However, keeping a Lithium-ion battery plugged in and fully charged keeps the battery's temperature elevated. Exposure to prolonged elevated temperatures can cause capacity loss which can then cause the battery to no longer be able to charge or hold a charge. Plus, it may be a small chance, but there is a chance that exposure to this condition for long periods could also increase the chance of a circuit failure (charging, high voltage, temperature sensing) and allow for a severe over-charge to take place to the point of thermal runaway which has been known to cause the occasional "exploding" battery, but in most cases just melt (and take some of the device with it) or catch fire.
A note regarding USB and charging:
Per the USB specs:
USB 1.1 = Minimum supply voltage is 4.4v
USB 2.0 = Minimum supply voltage is 4.75v
Both maximum supply voltages are 5.25v and a current of 500mA.
Before the USB bus interface can begin charging a device (Zen), it must return a device identifier to the hub driver (or device driver). Once the hub driver has the returned information from the device (like power requirements, supported transfer speeds, etc.), it can then begin charging the device based on those retuned values. This process is called Enumeration. Until enumeration has completed, it may not draw more than 100mA from the bus. Once enumeration has completed, it can then begin drawing up to the 500mA allowed by the USB bus.
Jun 23, 2008 | Creative Labs Zen Digital Media Player
RCA Lyra H100A
You must be running Windows 98 - see if RCA's website has the driver - you must have that driver or the installation CD - there is no other way (unless you get a computer running Windows XP or higher):
1. Insert the supplied installation CD into the CD-ROM drive first.
2. Read the readme file of the installation CD.
3. Double Click “77xinst”, then Restart Computer.
Method Two:
1. Insert the supplied installation CD into the CD-ROM driver and
connect the unit to your PC via the supplied USB cord.
Note: Do not select the charging battery mode after connecting the
unit to your PC. Please see page 4 for details.
2. If the player is recognized by your PC, the “Add New Hardware
Wizard” is activated, and click “Next”.
May 30, 2008 | RCA H100 MP3 Player
Philips GoGear SA5285/37  Digital Media Player Logo
76 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
