Question about Sony Walkman NWZ-S616F MP3 Player
Problems with my mp3
I got this mp3 about 6 months ago now and the problem is that my mother unplugged the wire pull it hard didnt use it until days after that so when i tried to transfer some music my computer didnt recognize it took it to the service they said that my mp3 had a virus they clean all and transfer some music to try and see it working seemed all good but now im trying again to transfer music and the same problem again is there any chance it could be my wire if they use it to fix it
  • 22 Answers
Probably damage to the usb cable....better to buy another one
Posted on Nov 15, 2008
I can not switch the water temp on my kenmore elite front load washer
I don't know about your problem specifically, but my washer wouldn't click on. After I set the cycle and pushed start, it just clicked but not on. It turns out that the mother board wires have a loose connect at that particular spot. The service man, not a Sears since they couldn't make it there for a month, unplugged the machine, opened the lid (screws on the top back) and pulled out and re plugged some wires. When he tried to start it again, it worked perfectly. Occasionally it will do the same thing, so I UNPLUG the machine, take the back off and wiggle the wires (I know which ones they are by now), put the lid back on, plug in, and wala, she works.
Like I said, this doesn't address your problem specifically, but it seems the wires in the mother board tend to rattle loose. I hope this is an easy fix for you!! I was relieved. Sears may have sold me a new mother board at the tune of $??? That service call was a year ago and, although it is sometimes annoying, I haven't had to purchase any parts.
Mar 10, 2015 | Kenmore Elite 45986 Front Load Washer
Can't reinstall game to phone .its a straight talk
www.lg.com/us/support/mobile-support
1 (800) 243-0000
Definately a memory problem.
Sep 14, 2014 | Cell Phones
1996 chevy 3500 7.4 vortec. the ecm fuse blows at the turn of a key
One of the power wire going from your ecm to a sensor or solenoid is shorting to ground. Get a wiring diagram and an ohm meter. disconnect the battery and start checking each wire measuring from the wire to ground. as you wiggle you will see the meter show 0 ohms when it is shorted. These are the hardest and most time consuming kind of electrical problems .good luck
Nov 21, 2011 | Cars & Trucks
Hello i have a 2004 expedition , and i have been having issues with my battery draining. about a month and a half ago i went away vacation , came home to start my truck only to relize my battery was dead....
Your solution is a little hard to find too bad they told you to change the alternator. It is a simple fuse you need to change that is blown. on the expetion sometimes there are two one in the fuse box and one under a black cover follow the alternator small wires it should point to the direction of the small i believe 7.5 amp fuse. it was hard to find and i do this for a living. good searching.
Apr 20, 2011 | 2004 Ford Expedition
About 3 weeks ago i was getting a code for the MAF sensor and a cylinder 4 misfire it was idling rough would die if i didnt gas it. pulled a MAF from a junkyard idle returned to normal also followed up...
I'm going to go out on a limb and sugest that you look for melted wires in the engine compartment. That would explain the burning plastic smell. And a bare wire grounding on your engine could cause about 100 diferent problems.
Sep 20, 2010 | 2004 GMC Canyon
I have an external 320gb HARD drive made by TOSHIBA i purchased about 3.5 years ago. Until recently everything has been OK with it but without warning the other day it didnt register with Windows on my...
unplug and replug the hard drive
if you have a software/driver for the external HDD uninstall and reinstall
if it doesnot work the issue is with the hard drive
Probably the hard drive has gone bad
Mar 07, 2010 | Computers & Internet
Misfires, I think? 60 mph to 5 mph
I would definitely have fuel pressure checked when this starts to happen. I suspect once fuel pump heats up, it's breaking down, thus starves engine for fuel & thus sets codes for misfire as well due to lack of fuel getting to cylinders. You'll probably show proper or close to, fuel pressure when started in morning or cooled off at night, but after driving & temperature gets hot, so does fuel pump, and then it breaks down. Fuel pressure test will confirm if you can set it up to have tested at right time.
Jun 29, 2009 | 1995 Nissan Altima
Starter went out wich somehow caused the ignition to go out
My mother just had a problem similar to this on her cavalier and it turned out to be a module unplugged underneath the car.
Feb 02, 2009 | 1998 Chevrolet Cavalier
JCD2295HES side by side not working correctly
yes that does sound like a bad evap fan motor then unable to circulate air aorund and off hte evap thus building up frost.you can pull the wire leads of the fan motor and ck for 110v. to confirm that you are indeed getting power to the motor.
Mar 05, 2008 | Jenn-Air JCD2295HES Side by Side...
Sony Walkman NWZ-S616F MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
