Sony tv kv25gxr1/shutdown after few minutes
Sir i would like to ask to how to fix this problem? before this tv is deadset and then i replace the ic voltage regulator the power is now is working and normal but when i turn on the tv after few mins goes off. i already check the voltage if normal and i found it is normal.sir give me some solution to this problem. thank you
MikeNJ1964
  • 398 Answers
SOURCE: Sony KV-32S40
When the horizontal output (2SC4927) is shorted it means one of 2 things is wrong - the horizontal drive transformer has cracked solder joints or the flyback transformer is shorted inside. If the solder joints on the horizontal drive transformer (the small grey transformer connected to the base of the horizontal output transistor) are cracked then the set will play for a little while and then the parts you just replaced will again be destroyed. ALWAYS resolder the driver transformer when replacing the parts you mentioned! When I replace the parts you mention and I do not see any obvious cracks on the driver transformer then I unsolder the B+ pin of the flyback (labeled 135, for 135 volts) and put a 60 to 100 watt lightbulb (drop-light) in series with the flyback. This means that the 135 volts B+ goes through the lightbulb and then into the flyback, so the lightbulb acts as a current limiter to protect the horizontal output. When you turn the set on the bulb should glow no more than about half bright and you should hear the high voltage come up, but you should not see a picture. If you turn the set on and the bulb glows as bright as if it was plugged into the wall then you can bet that flyback is shorted and must be replaced.
Posted on Jul 13, 2007
  • 556 Answers
SOURCE: JVC TV- MODEL AV-K21T.
it was not necessry to replace so many parts if you go as per proper procedure.please proceed as 1 isolate horizontal output section from power supply & make power supply ok. 2 if it becomes ok check hor osc,driver&h/output section. 3 if it is ok connect power input to hor.section which was isolated. 4 check for loose contact or print. 5 put on tv .
Posted on Sep 22, 2007
Shuttle83
  • 1139 Answers
SOURCE: Philips 21" L01.2A Chassis HV Shutdown
Hello bashlort, The increase in voltage may be to some circuit loading being removed this is a sign that something may have increased in resistance or something may have opened in the attached circuit. Have you taken any voltage measurements in the video section of the set, if not check the voltages on the pins of the video processor IC and follow the connections up to the CRT socket, be sure to pay special attention to the focus and screen grid voltages. If those are ok check the voltages in the horizontal section including oscilloscope measurements for drive signals. Please inform me of your findings. Thank you, Shuttle83
Posted on Oct 07, 2007
SOURCE: Sony Wega Blinking Standby Light
No... we got it to come back on and now we havent tuned it off since... we just leave it on 24 hours a day!
Posted on Jan 06, 2008
Russmann
  • 203 Answers
SOURCE: main power supply
If you changed the regulator and it still doesn't put out B+ you must have an open circuit somewhere. That model is known to have a 6.3 amp B+ fuse that opens and you must check it with an ohmmeter to tell if it's bad. replace it with a 7 amp fuse and you should be ok. If that doesn't solve it you may consider taking it to a shop. By the way, you're welcome for the tip. Two out of a hundred people said thanks for my time. Russmann
Posted on Dec 08, 2008
Infocus IN102 shutdown after a few minutes
You can use 256YN IC to resolve this issue.
This IC readily availabel in the market. Just change the IC.
Jun 23, 2014 | InFocus IN102 DLP Projector
My Sony KP-53HS10 was working perfectly fine last night. This morning we turned the TV on and it has a red, blue, and green, 3d effect. Could this be a loose color convergence chip? If so how do I fix it?
You do need a convergence board reworked. In some cases you may repair this at home. Generally the ICs you are looking for will have a 392 **** number. You will have to replace these. And any resistors you see standing tall on the board next to these ICs should be checked and replaced as necessary. The resistors will be about one watt and under 10 ohms. Checkout the website www.TvRepairKits.com and see if they have something to work with. Thanks for asking and give me a few hands please!
Sep 01, 2010 | Sony KP-53HS10 TV
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
No power up light blinks 7 times
this is a high voltage shutdown.......the high voltage has exceeded 33k,.....it causes the unit to shutdown for safety.check the power regulation as well as horizontal circuits.hope this helps
Feb 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv shutdown now blinks standby 6 times
a common fix for 6 blinks is an ic on the power supply board. the location is ic8002 locate and replace should fix your problem
Jan 25, 2010 | Sony KDF-55WE655 55" Rear Projection...
Deadset samsung 75e plus
Check the voltage at pin# 10 (+11.25 to 12.5V) TDA 4841/ TDA4856. If no replace the IC.
Jul 10, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Sony trinitron power will not come on sometimes
Hi
Can you give to me your diagnose test result..
Thanks!
Mar 06, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Nov 13, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
ABL protection active & color's spots
Replace the capacitor and the resistor as well as the diode that feeds the b+ to the vertical IC.
Sep 28, 2006 | Sony KV-32V26 32" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
