Question about Canon PIXMA iP4200 InkJet Photo Printer
I CHANGED MY PIXMA INK CARTRIDGE AND HOW TO RESTART?
I CHANGED THE INK CARTRIDGE AND THE PRINTER WILL NOT START. I GET A NOTE SAYING CLICK ON CONTINUE I DO BUT IT WILL NOT PRINT. HELP PLEASE.
    Problem Solver:
  • 6 Answers
Here's what you can do....
METHOD #1 - Easiest, but it disables the ink tank level indicators.
1) Ignore the low ink indicator, and press the RESET BUTTON to continue printing. If you press and hold the reset button for 5+ seconds, it will disable the counter for that particular ink tank. Refill tank now.
2) Repeat as needed.
You will get a dire warning that this will void you warranty, blah blah blah. If you do need to take your printer in during warranty and you've disabled ink tank counting, simple reset the entire printer as describe below for the wate tank warning, and nobody will ever know. SAVE YOUR CANON CARTS with a bit of ink left in- your printer will need to have Canon carts installed for warranty service.
3) Eventually you may be warned that the tank is empty. Press reset as above to disable and continue printing.
If you think this entire thing is ridiculous- you are right.
Get an earlier model that takes un-chip carts, like an ip6000, or ip3000, or i960. Much simpler and you get to use the ink tank indicators after refilling.
You can reset the entire printer with the WASTE TANK reset (below) when you need to clean or change the waste tank PAD (its really not a tank) See the above instructions for the i960 and similar for other Canon printer waste tank changes.
Here's the ip4200 reset options:
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power
in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Posted on Nov 06, 2008
When i gave print from doucment machine takes paper and give it as it as blank, solve my problem,
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge. NOTE: Depending on the printer, the estimated ink level indicators can vary in appearance. Examples of estimated ink level indicators c01867289.gif c01867290.gif
  7. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  8. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Restart the printer Restarting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer. NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the back of the printer. Figure 1: Disconnect the power cordc01869581.gif
  3. Disconnect the USB cable from the back of the printer. Figure 2: Disconnect the USB cablec01850063.gif
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 3: Reconnect the USB cablec01868577.gif
  6. Reconnect the power cord to the printer. Figure 4: Reconnect the power cordc01869582.gif
  7. Press the Power button (c01602202.gif ) to turn on the printer.
for more information see this page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&lc=en&dlc=hu&cc=hu&product=1138373#N46
i hoprt his helpful
thank you for using fixya
Feb 15, 2011 | HP Officejet 4355 All-In-One InkJet...
I can not clear an error msg saying " Check Ink
Hi!
Try to remove first the ink cartridges. Then, using a clothe moistened with alcohol, clean the contact surface of the cartridge where the terminals inside the printer touches. Then return back to its carrier the black and color cartridges. Restart the printer.
If error continue to appear. press and hold down the STOP/RESET button (the circle with inverted triangle button) Hold it down and wait until printer self restart before releasing it.
Just give this answer a good ratings if you want to thank me. And post back if there's still a problem.
Thank you for using Fixya.
Jan 21, 2011 | Canon PIXMA MP170 All-In-One InkJet...
When I Turn on my Canon Pixma Mp210 the error 6 pops up. I try to restart my printer, but it didn't help. What this error means and what to do?
Issue: ERROR LED: E, 1, 6
Solution: Press and hold Stop/Reset button for at least five seconds
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Solution: Replace ink cartridge(s) MP210
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
    *MP470 shown
  2. Press down on the semi-circular tab (circled area in <1>, above) to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  5. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  6. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  7. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  8. Fold the scanning unit support and close the scanning unit (printer cover).
  9. Wait until the preparatory operation is complete; it takes about one to two minutes.
Trust this is helpful. :)
Dec 10, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Re Canon 2600 printer.I recently purchased a black Ink cartridge and replaced the old one. A week later the color cartridge also shows empty even though I hardly use color. Can I not print in greyscale...
Please follow the instructions below from Cannon support page...
Setting the Ink Cartridge When printing, you can specify which ink cartridge to use. This is convenient if one of the ink cartridges becomes empty, you can continue printing by specifying the ink cartridge that still has ink. Note:
  • When the following settings are configured, Black Only is disabled. The color ink cartridge is used to print.
  • A type of paper other than Plain Paper is selected for Media Type on the Main tab.
  • Borderless Printing is checked on the Page Setup tab.
  • Canon recommends that you use the ink cartridges installed in the printer and not remove them until the ink runs out.
You can set the Ink Cartridge Settings from the Maintenance tab in the printer driver.
To access the printer driver from the application software, click here.
To access the printer driver from the Printers folder, click here.
Application Software -
Note: Depending on the application software, command names or menu names may vary and there may be more steps. For details, refer to the user's manual of the application software.
  1. Select the command you perform printing on the application software in use. In general, select 'Print' on the File menu to open the Print dialog box.
  2. Select your printer model name and click 'Preferences' (or 'Properties'). The printer driver setup window appears.
  3. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  4. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  5. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  6. Click 'OK' on the Ink Cartridge Settings window.
  7. Click 'OK' or the applicable button to print.
Printers Folder -
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
For Windows Vista
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
  • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  1. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  3. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  4. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  5. Click 'OK' on the Ink Cartridge Settings window.
  6. On the Printing Preferences window, click 'Apply'.
Mar 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Changed the ink cartridge when i turn it on i get e 2 and alarm
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq8
Jul 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I change the ink?
Go to this link. Type "replace ink" in the search window in the center of the screen and click on the Search button. Now click on the 'How do I replace ink cartridges' link and you will get an illustrated, step by step guide. Note that the printer must be turned on when starting this, and the cartridges will move over to the left side.
Mar 09, 2009 | Canon PIXMA MP470 All-in-One Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Ink cartridge
Go to this link. Type "install ink" in the Search box and click on search. Click on the line "how do I install ink cartridge(s)" and you will get specific guidance on installing the cartridges. Make sure that the printer is turned on as noted in step 1.
If you click on the tab that says Drivers & Downloads, you will be able to download a manual for your printer.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Not printing
The remaining levels of the following ink cannot be correctly detected.
Color
The following ink is running low.
Black [830]
Prepare a new ink cartridge.
The resulting print quality may not be satisfactory, if printing is continued under this condition.
If either black or color ink cartridge has run out, you can set the printer to continue printing with the other cartridge from the Ink Cartridge Settings on the Maintenance tab of the printer driver.
----how to resolve it
email me: akemzone@yahoo.com
Feb 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
356 people viewed this question
old marine
old marine
Corne Viljoen
