Question about LG Washing Machines
LG wd8013F bowl support plastic pin fell out. I turned machine upside-down, replaced plastic pin, now doesnt wash or spin.
(A) Set-up
1) The inner bowl is supported by (2) heavy springs at the top, plus (2) telescopic shock absorbers beneath the bowl.
(B) Observed Problem
1) Inner bowl was missaligned, causing out of balance knocking & banging, also drive belt was squealing from misalignment.
(C) Remedy:
1) Disconnect power from outlet.
2) Remove (4) screws from back plate, remove back plate.
3) Bowl is suspended on (2) heavy springs from top, and (2) telescopic shock absorbers below bowl.
4) Inspection showed plastic pin retaining shock absorber end to frame had fallen out.
5) Place old carpet or whatever on floor, invert washing machine.
6) Re-align end of shock absorber into housing piece.
7) Re-insert plastic pin (about 2 inches long x 1/2 inch diameter) securely into place.
8) Re-assemble.
Also:
a) It could be one of the top springs as per (B)1 above may have broken or become loose.
b) In this case the top cover plate is easily removed from machine by removing (2) screws at the rear top of cover.
This gives access to the (2) heavy springs, which are easily repaired.
Note:
Sometimes the machine will not re-start again following out of balance problems.
1) Turn power off again, re-boot like computer.
2) There is also a re-boot procedure similar to Alt+Ctrl+Del on computer.
3) Use three buttons simulateously, Start+spin+option buttons or similar.
4) I fiddled with these until all lights lit up, then after a while the machine worked satsifactorily.
Cheers
Posted on Nov 07, 2008
How do I my wedding ring out of my washing maching, it fell in there last night, on the top part between the lid and the top back part
If it fell between the bole and the housing the cover will have to be removed. if it can be turned upside down it may fall out. If it is inside the bole it may be under the agertater or or in the water pump housing.
Jul 18, 2014 | LG Washing Machines
Main power flicks off when my LG wd8013f starts
There is something grounded in your washing machine.
Jul 13, 2012 | LG Washing Machines
Money fell under the spinner
I take it that you mean that there is monetary coin or coins stuck between the Wash Bowl and the Spin Bowl. If the diameter of the coinage is greater than the Wash Bowl outlet, the coins will never find their way to the emptying pump of the machine, and will continue to rattle around inside. However any of the coins can enter the Wash Bowl outlet this could result in the water pump becoming jammed or damaged requiring replacement. I have solved this problem by removing the top of the machine (HOB) above the washbowl then completely removing the shroud over the Wash Bowl...then replacing the top of the machine firmly. By then turning the machine upside down, the coins will drop out and can be retrieved. Finish the job by returning the machine to the upright position.
Oct 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine wont pump out water, stops before spin cycle is a wd8013f cheers
Try emptying the filter n then put it on a boil wash (empty) it mite jst b glogged up :-)
Feb 20, 2011 | LG WM-2277HW Front Load Washer
When in spin cycle it acts like it is out of balance and shuts down even with nothing in it.
I have the same problem after replacement of coupling .When I replaced the coupling by turning machine upside down, Two pins fell out and I do not know where to place the pins ANY Suggestions
Mar 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine not spinning
The pin is a shipping pin and serves no purpose after the machine is set up. These machines comes with a plastic strap through the back panel to hold components in place for shipping. There are plastic cups that the pins fall into after the strap is pulled.
Ignore the pin.
Your no spin problem is a stripped out direct drive coupling between the motor and transmission.
It is a easy fix.
Use the attached video as reference to change out the part.
Apr 21, 2009 | Kenmore Washing Machines
Transmission problem of a washer Whirlpool model LXR7244JQO
Good morning.
The problem lays in the transmission. From outside when you turn the universal (connector) the bowl with the brakes don't turn with the main shaft. When you open the transmission, remove the clip of the big plastic gear. After you lift up the plastic gear you will notice that one or two of the plastic parts are worn down. By replacing you will solve the problem.
Jan 21, 2009 | Washing Machines
Primer button bowl brass bolt and plastic.
what is plastic ? all there should be is a bowl , then small round gasket , then brass nut . if it doesnt go on you must have disturbed the bowl gasket ( black round )
Sep 19, 2008 | Garden
LG washing machine, Model WD8013F
Hi this is a common problem theres a was a kit where you fit an extra counter weight to the front plus strenthening screws for the frame sometimes i changed the shocks.
Sep 01, 2008 | Washing Machines
Washing Machines Logo
180 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
