Question about Mitsubishi CS-35707 35" TV
TV lacks green, but has prominant red/pink
I recieved a free tv that has a certain tint to it that is strange. There is no green on the set, any time something green is displayed on the tv, it's replaced with black. However, the red and pink is very strong all over the set. It seems the only problem is trying to get the green color back. I was told this might cost a bunch to fix so I'd like to do it myself. If anyone knows ANYTHING about how I may fix this, i would be incredibly appreciative! :)
  • Kris Brand Oct 12, 2006
    I have found the little color outputs on the neck of the tube, there are 6 total which are grouped in sets of 2. There is a paint strip that appears to line up if you move them in the right direction. Does this piece have anything to do with it?
    Sergeant:
  • 337 Answers
Getting the squematic will be the first step to take to become more familiar with the electronics inside,you can ordered by going to http://www.servicemanuals.net/ click on service manuals and give them the model number,they will then give a price and availabilty.The color processing uses a driver for each color and an output for each color too,the output are ussually placed in the crt board in theneck of the tube.the drivers and outputs are transistors most of the time but sometime the drivers are part of an integrated circuit.Please let US know if you need more help but place it as a new question.
Posted on Oct 11, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    Rating the response is important to the person helping you
Problem: my sylvania SRT2232X 32 inch has green tint on every channel
A green tint can be caused by over drive of the green circuit or lack of enough red or blue.Either way it leads back to the tube having a problem. If it is even available the cost of replacement would well exceed cost of buying a new TV.
Sep 22, 2009 | Televison & Video
Color has strong green tint - can't adjust with set-up program
One color plug in the back was unplugged - Since the TV had not moved we didn't think to look for that. The cable bundle must have been bumped causing the problem - I feel a bit silly that I hadn't looked for that. Thanks for your follow-up.
Jun 12, 2009 | Panasonic TH-42PX60U Television
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white...
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Jan 15, 2009 | Televison & Video
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Green tint on a SRT2232S
  • green tint & also very prominent when there is a black screen.
  • this problem is due to degaussing effct or magnetic effct in tv.
  • please remove magenatic material near tv like speaker or headphone.
  • if you have turned the direction of tv please bring to normal put the tv on & put it off for 30 minutes & now put it on it will be ok.
  •  do not turn tv when it is on
  • hope this will help.
Oct 22, 2007 | Sylvania SRT2232S 32" TV
TV lacks green, but has prominant red/pink 3
Excellent pictures of the crt board I can actually see the transistor ans is mounted in a piece of metal with a screw holding it,is just to the right and he should be the only one of this kind in the board,this transistor is soldered in and it needs to be replaced with same,in its face it has some number ,the part can be ordered or cross to a replacement with those numbers.Make sure all the conections on the board are solid.Let us Know how it goes.
Oct 12, 2006 | Mitsubishi CS-35707 35" TV
TV lacks green, but has prominant red/pink (Question 2)
Those are magnets and not outputs ,the outputs you might be looking for are in the crt board and is an actual transistor,do not move the magnets and try to realign to the way they were,the crt board is at the end of the neck of the tube and it can be remove very carefully,do not twist this board or the picture tube might break and then we are in trouble.Take a picture of the board it should be about a 4"x4" in size.Make sure the set is not plug in when you work around this parts.Lets Us know when you need more information.
Televison & Video Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
