Question about Bosch SHU3305 Dishwasher
Bocsh dishwasher no water is coming into my dishwasher
  • mikebev Apr 12, 2009
    It reads 2H and the motor runs but no water. It is used regularly.
  • 457 Answers
CHECK UNDER THE SINK AND MAKE SURE THE WATER IS COMING INTO THE FILL HOSE. DISCONNECT AND RUN IT INTO A BUCKET TO CHECK. THEN IF THAT DOESNT WORK THENHIT THE DRAIN AND CANCEL BUTTON THEN START MACHINE.
Posted on Apr 19, 2010
My Bocsh dishwasher has stopped mid cycle. there is water in the bottom of the machine,the check water light is on and there is traces of water on the floor under the machine, what is my problem and how...
Check the drain hose for kinks or clogs all the way up to the air break on the sink. If that's all open check to see if the pump has an obstruction, food spoon etc that stops the impeller.
Jan 06, 2014 | Bosch Dishwashers
When troubleshooting my shx46a05uc bocsh diswasher it show a flashing light on the delicate/Eco button and regular wash light stays on. What does that tell me?
sounds like the electronic switch usually a Thyristor is not switching when you push the eco button, You could try disconnecting the the machine from the mains then push the buttong in and out a few times to see if the push button has a bit of dust on the contacts..
Sep 18, 2013 | Bosch 24 in. SHX46A05UC Built-In...
I installed a new bocsh dishwasher and garbage disposal. The water is not draining. I routed the drain hose on the floor rather than looping it up the back of the dishwasher, due the short lenght of drain...
If you did not remove the plug from the disposer drain where you made your drain connection will cause the dishwasher not to drain. This should have been mentioned in your installation instructions. Also, routing the drain hose other than what is specified in the instructions, will allow food waste to enter the dishwasher when you grind food in the disposer. Read your instructions and don't take shortcuts, you want to have your appliances work well for a long time, as you have made a considerable investment in some quality appliances.
Hope this helps!
Jul 16, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher not letting water in
I think that this is probably the water inlet solenoid. It would tend to vibrate a little if it is trying to open.
It should be a part with an electrical plug going to it and also be hooked up to your water supply.
These are generally not very expensive and easy to replace
Apr 16, 2009 | Dishwashers
ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
What should i do?
I think this dishwasher is sold by lowes
ask them if they can copy a few pages that you need
other wise go on bocsh .com
Jan 31, 2009 | Dishwashers
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Bosch dishwaser
need to look at operating booklet and see what F stands for.then rectify it.
Oct 05, 2007 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch SHU3305 Dishwasher Logo
194 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
