I have a Xerox 6120N. My router config is 192.168.0.2 and my printer IP is 192.168.0.4. I've also did the TCP/IP printer setup with XP and it's setup as 192.168.0.4. Do I need to enable something in my router in order to print cause I this point I can't print anything.
What is the current state of the printer under Printer and Faxes on the Control Panel? If it's offline after you setup TCP/IP printing just right click on the printer icon then change the status from offline to online your printer should say ready below it and to test if it's already associated to the network try to run a "ping" test from your computer and check if you will get a reply from 192.168.0.4 which is the IP address of your printer as you mentioned. If your gettings time outs try to disable all the firewall and antivirus on your computer usually that will do the trick.
Trouble setting up Zoom modem/router with PSP model 559OE. It never finds the ip address so I do a...
(More)
Trouble setting up Zoom modem/router with PSP model 559OE. It never finds the ip address so I do a manual setup and it still won`t work I could be entering the info wrong I know it work because my DS works with it
i have a wireless router (netgear rangemax) and had my laptop connected to it. I connected my ps3...
(More)
i have a wireless router (netgear rangemax) and had my laptop connected to it. I connected my ps3 to the internet and now i cannot get internet connection thru my laptop. my network says i have connection with limited access. but basically i have no access. can you help?
We purchased a D Llink router which we have installed but it does not communicate with the new...
(More)
We purchased a D Llink router which we have installed but it does not communicate with the new printer we got to go with it or the PS3
