Question about Motorola Mobility RAZR V3c Cellular Phone
Removing Sim on Motorola Razr
Sim pinned in by cover bar. How do you remove without tearing up bar or sim?
  • Treloss
    Treloss May 11, 2010
    Which Razor is it?
    Brigadier General:
  • 7,752 Answers
You will need to use a small flatbit screwdriver to remove it
Posted on Dec 27, 2008
Motorola RAZR resetting factory settings without sim card
Our Android Motorola Razr can be externally reset.
How do reset my DROID RAZR
Our Motorola Razr V3 cannot be reset if you forgot the PIN. You can push Menu and then try to enter t he security code 000000
Mark
Motorola Support
Apr 21, 2014 | Motorola RAZR Cell Phones
How to get micro sim card stuck in motorola razr v without the sim card tray?
Exchange unit under manufacturers warranty.
While the Razr HD and Razr M use a micro-sim, the Razr V uses a normal sim(really a mini sim). The micro -sim is exactly half the size of the required sim and fits perfectly sideways into the slot. If you push it with another sim card you can make it click into and out of the mechanism. It will come back as far as the spring pushes it, but no further, and because it is only half the size, there is nothing to grip onto, and it is still under gentle pressure from the contacts. Removal of the the back cover and non-removable battery still does not allow access to the rear of the slot so the sim can be pushed out.
Ask Motorola for DOA warranty replacement and keep the faulty one as a 4" wifi tablet.
Dec 24, 2012 | Motorola Cell Phones
How do you change a sim card in a motorola v3
Hello
If you want to change a sim, switch off the phone, remove the back cover, remove the battery gently remove the sim an place the new sim.
Put the battery again, cover the phone and switch it on.
Thanks.
Aug 11, 2010 | Motorola Mobility RAZR V3x Cellular Phone
How do I remove the Sim card from a Motorola Razr V3M cell phone?
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
Good luck to you.
Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
I am getting a random error message on my Motorola RAZR V3 Celluar phone. It says I should insert the SIM. The message goes away when I reboot, but it reappears. Can anyone help?
Remove the back cover, battery and SIM card. Wipe the SIM and the pins where the SIM card is inserted with a cloth if u can. Reinsert simcard, battery and back cover.
Aug 24, 2009 | Motorola Mobility RAZR V3
Replace a sim card
Replacing the Sim Card on a Motorola RAZR
  1. On the back of the phone you should see grooves for you to slide off like batteries on the back of a remote.
  2. Slide off the plastic cover.
  3. Remove the Battery.
  4. You should now see the Sim card.
  5. Slide the Sim Card out / Lift up the hatch and take it out.
  6. Slide the other one in / Insert the new one and close the hatch until you hear a slight noise of it clipping in.
Oct 01, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Taking sim card out
Hi, first go here:
http://www.somelifeblog.com/2007/03/motorola-razr-v3-how-to-remove-battery.html
to remove the back and the battery from the phone, then go here:http://www.somelifeblog.com/2007/03/motorola-razr-v3-how-to-remove-sim-card.html
that will show you how to remove the sim card :)
Hope this helps, if not let me know :) Si
Oct 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Razr V3i charging problem
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
May 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
