Cannot insert columns in excel spreadsheet. Comes up with error cannot shift object off sheet
    Scholar:
  • 42 Answers
This error message occurs if the following conditions are true:
  • The option Nothing (hide objects) is selected in the Display options for this workbook section in the Excel Options dialog box.
  • You create an object, such as a cell comment, in any cell in a column.
  • You try to hide the column to the left of the column that contains the object, the column that contains the object, or all the columns to the right side of the column that contains the object. Or, in some cases, you try to insert a row or column in the worksheet.
There are two ways to fix this problem.
Method 1:  Temporarily toggle the option from "Nothing (hide objects)" to All In Excel 2007, temporarily toggle the option from Nothing (hide objects) to All, and then insert the rows or columns as needed. To do this, follow these steps:
  1. In the upper-left corner of the Excel window, click the Microsoft Office button.
  2. At the bottom of the menu, click Excel Options.
  3. Click Advanced from list of options on the left.
  4. Scroll down to the Display options for this workbook section, and then click All under For objects, show:, and then click OK.
Notes To use the keyboard shortcut to toggle this selection, press CTRL+6.
If these steps do not let you hide rows or columns or insert rows or columns in Excel 2007, try the steps in method 2.
Method 2: Change the position property of the object to Move and size with cells To work around this issue, Excel 2003, Excel 2002, and Excel 2000, change the position property of the object to Move and size with cells. To do this, follow these steps:
  1. If the object is a cell comment, select the cell that contains the comment, right-click the cell, and then click Show Comment or Show/Hide Comments. Note This makes the comment visible.
  2. Move the pointer to the edge of the object until the pointer changes into a white arrow with four small black arrows on the pointer. Then, click the object to select it.
  3. In Excel 2003 and earlier version of Excel, click <object name> on the Format menu. Note In this menu command, <object name> is the name of the object, such as "Comment" or "AutoShape."  In Excel 2007, click Format <object name>.
  4. In the Format dialog box, click the Properties tab.
  5. Click Move and size with cells, and then click OK.
  6. If you want to hide the cell comment again, right-click the cell that contains the comment, and then click Hide Comment.
  7. Follow these steps for each object in the affected column as described in the "Cause" section. When you hide the columns, you do not receive the error message.
For more information, visit the Microsoft Knowledge Base article: http://support.microsoft.com/kb/211769
Posted on Nov 06, 2008
  • Harish Swamy Oct 02, 2010
    Thanks for the explanation
    Other sites presumed there was data in these reanges
    Harish Swamy
  • miranda_rd_1
    miranda_rd_1 Jan 06, 2013
    Hi! I just posted this solution here:http://runakay.blogspot.com/2013/01/inse...
Cannot hide error"cannot shift objects offsheet"
Posted on Jan 05, 2010
How do I check that I have copied the formula to a new cell?
Click on the column-heading to select the entire column.
Right-mouse-click to select "copy".
Move the mouse-pointer to where you want the copy to appear.
Right-mouse-click and choose "insert copied cells".
Sep 16, 2014 | Microsoft 1994 Office Excel Spreadsheet...
I have a column containing a value of a single letter. I need the spreadsheet to sort add rows by letter.
Move the column to A. Mark entire sheet and sort ascending. There are more raffined ways to do this, but this is an easy quick fix...
Sep 07, 2014 | Microsoft Excel for PC
Sum numbers in a column down until you come to a blank, then start again
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Sep 03, 2014 | Microsoft Excel for PC
Add information to grayed columns
any greyed out area is a non accessible are
either the spread sheet your are using is not advanced enough or that area is read only requiring an administrator's authority to access it
suspect that it is read only and is not for editing
if you go google and type in -- user manual for excel spread sheet-- there is a pdf version ( around 900 pages ) which has everything you need to know for excel spreadsheets
a good publication if you spend lots of time in excel as it misses nothing
May 11, 2017 | Savy Soda iSpreadsheet Free
When i open an excel spreadsheet, the columns go right to left instead of left to right.
  1. Click Options on the Tools menu, and then click the International tab.
  2. Do one of the following in the Right-to-left option group.
    • Click Right-To-Left to have new objects displayed in a direction familiar to right-to-left users.
    • Click Left-To-Right to have new objects displayed in a direction familiar to left-to-right users.
Nov 10, 2013 | Microsoft Excel 2010
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    Working in a spreadsheet I want freeze column A, so that the rest of the sheet move horizontaly. working in quattro pro 10, I want column A to not move while I scroll left and right ith the rest of the...
    In Excel and even Mac Numbers, these columns can be locked and shifted around with ease by accessing the Edit > Lock feature.
    In quattro pro...no idea. This was made almost 9 years ago...might be time to upgrade to something a bit more full featured.
    Nov 23, 2009 | Microsoft Windows XP Home Edition
    Cannot shift object off sheet excel
    if you have inserted new comments , please delete them. The problem should be over.
    Apr 09, 2009 | Microsoft Office Excel 2003 for PC
    Duplicacy in excel sheet
    Since you are searching the data by the phone number , first select all the data in the spreadsheet and sort it in ascending order by the phone number.
    Then, assuming you have 5 columns of data A through E, and the phone numbers are in column E, with row 1 occupied by column headings, use the following formula in cell F2=IF(E2=E1,"Duplicate",1)
    Drag this formula down column F till the end of your data
    Select the entire data and do an auto filter
    In column F filter the data by Duplicate and delete all these rows
    What remains should be unique data
    Dec 19, 2007 | Computers & Internet
    Open Questions:
    Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
    Feb 19, 2018 | Facebook Computers & Internet
    Computers & Internet Logo
    3,242 people viewed this question
    David Payne
    David Payne
