Question about Jl Audio 1000/1 Car Audio Amplifier
Jl 1000\1 v2 and 13 w7
What tuning should i put???????????
It depends on how you wired your 13 w7 did you wire the dual voice coils up or down?? the w7 comes with a book and it has the 1000/1 settings you need and then there is a guide that comes with your 1000/1 v2 and on page 14 it tells you how to set the gain accordingly to your ohm load for perfect sounds with little to no gain overlap (you can set the gain louder if you don't want maximum sq and are not worried about clipping cause a 1000/1 shouldn't blow a 13 w7 from overpowering only from clipping (and since the w7 are practically bullet proof clipping takes a long time)
Posted on Mar 31, 2009
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Amp assistence
The jl100/1v2 puts out the same amount of power between 1.5 - 4 ohm loads so you dont have to really set up anything to match your sub- wire the coils in parrallel and plug it in- set infrasonic(subsonic) filter at 15 hz(lowest) set crossover piont at close to 80 hz set gain about half-or if you kow the voltage from your source unit match the source voltage to the amps input voltage setting-it should pound like a champ with no problems
May 20, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Complicated JL Audio Amp
1. set the amp LP filter frequency at about 80hz and mode/slope to 24db.
2. set the amp gain as recommended in the manual.
3. set the subsonic to on and to about 25hz
4. ste the bass eq to off!
5. set the input voltage to low and signal sensing to off
6. Fine tune by ear.
Oct 28, 2008 | Jl Audio 13W7 Car Subwoofer
JL audio hook up problems!!??
your w7 13's are dual 1.5 Ohm, but according to JL website, are 2.41 Ohms when the coils are in series. Each 13 connceted to each amp with voice coils in series is your best bet. The amps are designed to put out the same amount of power from 1.5 to 4 Ohms. If you parallel the voice coils, you end up with .6 Ohms and the amp will go into protect mode. You'll be drawing a lot of current, so you may want to think about 1/0 guage power wire, upgrade the wire from the alternator to battery (usually only 8 guage) and think about multiple batteries.
Feb 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
667 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
