Question about Digimate DGL26 Television
Audio cuts in and out. Can restore by shutting off tv or cycling the mute.
The audio cuts in and out for no apparent reason and is bery hit and miss. It can be restored by either turning the TV off and on or by cycling the mute control.
Yeah, i have the same problem, no anser, just a note to say i have the same problem
Posted on Nov 22, 2008
Where can I find parts for a JVC C-1455CA tv?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 29, 2015 | JVC Televison & Video
How do I restore sound on my tv ?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2015 | Televison & Video
LG TV 55LD520-US having audio problems. No audio, when shut off speakers and turn on audio comes back on. This is continuous on this LG TV.
Sounds like speaker fault. Contact any service technician. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Feb 18, 2015 | LG Televison & Video
No audio on Sceptre TV
I think that you missed to check its speakers. Check it. If they are found OK, the audio output section circuit should be troubleshooted.
Jun 11, 2012 | Sceptre X46BV TV
SPEAKERS NOT WORKING
Try these guys at: http://www.generalsystemsconsulting.com They can provide phone support for $25.00 that you will pay through PayPal. You only pay if the problem is solved. Speakers don't work for one of the following reasons: 1) You don't have it plugged into the Light Green colored port in the computer, 2) You have the volume muted, 3) The Audio Driver is corrupt or missing, 4) The Codec is missing
Mar 09, 2012 | Computers & Internet
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
No audio
went into setup, tv and kept hitting the mute then unmute it finally took. Not sure what was wrong with it since I had already done that several times. The two audio outputs on the side of the tv do not work like it says in the manual for surround sound. Its definitely a cheap tv.
Jun 21, 2009 | Olevia 227-S11 27 in. LCD TV
Phillips 50
There was a problem with the software several months ago. with that issue.
Turn on your TV and enter to following code 123654 on screen you should see a software version something like BJ24u 1.6
U can download current firmware from Philips consumer portal
Apr 18, 2008 | Televison & Video
Unpredictable audio output for no apparent reason
That click sound when the tv turns off is normal, that is just the relay from the power supply shutting off.
When you turn the tv on, do you hear a faint “pop” noise from the speaker? If so, the problem is with the heat sink under the audio IC. Over time, the heat sink will lose its consistency and start to melt, thus shorting out the audio circuit. To fix, you’d need to clean off the melted residue on both sides of the audio IC as well as replacing the heat sink with a newly redesigned Sharp Heat Insulation Pad. It’s a pretty complicated fix, I suggest calling your local authorized sharp service center to fix this problem. The part is inexpensive, so you’re most likely looking at a labor charge (maybe around $200ish) for the repair if they are not marking up the price too much.
Oct 17, 2007 | Sharp LC-37D6U 37 in. LCD Television
Digimate DGL26 Television Logo
79 people viewed this question
Top Digimate Televison & Video Experts
Jaime Hernandez
Jason Morris
Computer Repairing
Computer Repairing
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
