Question about Acer Aspire 5000 Notebook
Hard Drive Issue
I have the Acer aspire 5000, and I have tried several times to format the HD and replace the OS, but when I goto setup, the screen states that there is no HD in the computer. Any ideas? The HD trys to boot, but then stalls and repeats several times with no luck.
  • 33 Answers
Hi man .. its just simple dont get tensed ...
goto bios ... in that some wehere there willl .sata support for hdd .. in that make the hard disk .. to native mode or compatibiltiy mode. . then boot .. u can see the hard disk ... just done ...
enjoy ..
Posted on Nov 06, 2008
Replace hd with used hd.
You just do not drop in a replacement hard drive from another working computer and expect it to work. The replacement hard drive is now in a "foreign" environment and often will not work to protect the existing operating system. If you have the operating system disks you may be able to do a "repair" operation where the OS is given a chance to adjust to is new environment and install new drivers. If not, then all you can do is format the replacement unit and re install all of the software; everything is one drive is lost and you start from square one.
Nov 23, 2013 | Acer Computers & Internet
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
I have an acer aspire 6930 after a little over a year the hard drive crashed. I bought a new hard drive and also purchased the receovery discs from Acer but I keep receiving an error code restore failed...
Sorry you are having trouble. I can help you with this. The "Format" command has been around for a long time. It used to be included on the start disks that came with Dos, Windows 95, and Windows 98. Now that the Operating Systems (OS) are much bigger and most pcs do not have floppy drives we have to use other methods to get to the format command. Now comes the hard part. Format is a DOS command. To use you have to be at the c: prompt. It is still included in most OS's but the trick is to get to it. Try this: Boot to the CD that contains your OS. Then search the disk for the format command. Once you know you have it you will have to pick the option to goto the recovery console. Here you will have to have the administrator password to continue. If you need more info please ask
Apr 07, 2010 | Acer Aspire 6930-6455 Notebook
My acer 4315 laptop wont detect it's hard drive. during O.S. installation it tells me setup did not find any HD drives installed. Make sure any HD drives are powered on and properly connected.'' I checked...
Try to DISABLE SATA in BIOS.
To Enter in BIOS pelase Follow these steps.
1. Power ON computer and Press "DEL" or F1 or F2 or F10 to enter BIOS.
2. here you can find SATA Option . and Disable it
You can refer Manufacturer Manual to perform this task.
Regards,
Mar 30, 2010 | Acer Aspire 4315 Notebook
How to format hard drive
To format any extended or external hard disk
Right Click the drive (example D:\ )and select the FORMAT Options
Click START to Format the Hard Drive. The time to format depends on size and the condition of the Hard Disk.
Feb 15, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Acer aspire 5000 laptop. black screen says NTLDR missing, press any key to restart..but it will not do anything just stays on the black screen with the message
try repairing the OS with the installation disk. if this doesn't work, try formatting the hard-drive, but remember to connect the hard-drive to another computer and backup your important files. this is the simplest way to solve it, as trying to restore the system manually requires lots of command lines and a system boot disk.
Feb 06, 2010 | Acer Computers & Internet
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Cannot format c:
if you want to format it you have to reinstall the os . Actually all information of the os is sitting in c drive ... in running time of windows you can't format the c drive .....
To format and reinstall the os get a windows(XP,vista,98) botable cd ...boot from cd ... it will start the setup...... in middle of setup it will ask for the format ......
Nov 16, 2009 | Acer Aspire T650 (AST650UC3601) PC Desktop
Blue screen on my laptop when I start reinstalling a deleted win Vista OS
I would get a different hard drive. Hard drives can be very tricky sometimes. I had that problem with My D600. replaced the hard drive and everything was okay. Hope that helps.
May 25, 2009 | Acer Aspire 6930-6771 Laptop
Acer aspire 1 will not load XP
If this a new drive you need to prepare it using a hard drive utility before windows will recognise it. The drive manufacturer may provide this for you. Maxblast is one such program as is Datalifeguard from Western Digital.
May 05, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 5000 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
