Question about Sony Handycam CCD-TRV308 Camcorder
CANNOT EJECT TAPE
I PUSH THE EJECT BUTTON THAT IS UNDER THE TOP COVER AND I CAN HEAR THE MECHANISM OPERATING BUT THE TAPE WON'T EJECT.
Thankyou. I do have the problem solved for now. I found a section about solutions in your web page. Several readers had the same problem. I was about to use a hammer on it but some of your readers came up with idea to slap the camera a couple of times on both sides and by golly it opened up. I was taught to handle sensitive items like the camera with care and to avoid jaring the item, but, this time I was lucky. we will see.
C. Ness
Posted on Nov 07, 2008
Got a mitsub Hs-u430 vcr.Pluged in & immediately starts eject.Does twice then stop.Only halfway eject.Does with no tape in.Took cover off & help tape in.Push any button it does same all over.
Disc loading mechanism fault. Contact any service technician. The mechanism should be taken out from the set, for repair. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 26, 2016 | Televison & Video
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
I will push the eject button , i will hear several clicking sounds and the panasonic will turn off and the tape will not eject.
There's only one way to tell what's wrong with and that's to take the top off and look inside. There are lots of things that can go wrong with the mechanism, such as plastic parts broken and tape entanglement. But looking inside is the only way to tell what's gone wrong. You can then give us a fixya more info so we can help you get it working again.
Aug 06, 2010 | Panasonic AG-1980 S-VHS VCR
My sony Hadycam vision CCDTRV118 the tape is stuck inside camera and can't remove it
Hello. First, do not force anything!! Secondly, make sure the battery is properly charged. Next, in playback mode, try to rewind or fast forward the tape--this causes the recording, audio, etc. heads to retract away from the tape and *might* free it if that is the cause. When you open the outer cover to trigger tape eject, do you hear the tape mechanism motor running? If you don't hear anything or the mechanism is truly jammed, it will require a tech to remove the tape and repair/replace the insert/eject assembly. Send the unit directly to a repair facility unless the warranty is still in effect.---Hope I was of some help.---Rick
Oct 02, 2009 | Sony Video Cameras
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Eject a tape from my Sharp View Cam
Try removing the battery and reinstall it if you haven't all ready tried this
Sep 11, 2008 | Sharp Viewcam VL-A10U Camcorder
Tape doesn't eject all the time
This probably indicates a problem with the mechanicals. The tape carriage mechanism might be out of whack/bent/or broken. You might take the top cover off and see is the mechanism is sticking somewhere.
Unfortunately, modern VCRs (last 10+ years) are very cheaply made, and disposeable, unlike the machines of the '80s which were built like tanks in comparison. Thus, unless the problem is minor, repair is doubtful.
May 05, 2008 | Televison & Video
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Tape will not eject
This mceahnism is now defective and only a skilled workshop technician can do this job. If you need the service manual and parts we can help. Siva videolabs@gmail.com
Jan 03, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV308 Camcorder Logo
163 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
