Question about GE JES735WJ Microwave Oven
Need to operate the microwave at 230 volts
I have purchased the microwave and need to use it in a country which have 230 volts. What will I need to use the device?
  • Tushar Nerurkar Oct 12, 2006
    Thanks a lot for the response.
    I already have a 1000W step down transformer. Will connecting that create some issue with the operations of the microwave? I havent tried connecting it till now..so am really not sure how the microwave will function.
  • GE Master
  • 9,149 Answers
You will need a step-down transformer of the appropriate power (wattage) and the proper adapter plug for the country you'll be in. You need to look on the back of the microwave and see how many watts it CONSUMES, not how many watts of cooking power it produces. Usually the power consumption requirement should be in the ballpark of twice the power output. For a 700W (cooking power) oven, I would suspect it has about a 1400W power consumption requirement, so your step-down transformer must be rated at least 1500W. That may be cutting it close, so for lower heat and longer transformer life, I would choose a 2000 watt model. You need to be sure it comes with an adapter plug that's made for receptacles in the country you'll go to. One site I found has them for about $60. but I would read up on the subject to see if you need one of an EVEN HIGHER rating since microwave ovens do surge when they start cooking. You may need to use one rated at 3000W or more. More info: http://www.dvdoverseas.com/store/index.html?loadfile=itemthg2000.html
Posted on Oct 11, 2006
  • William Miller
    William Miller Nov 11, 2006
    Please re-read my previous post.
    I do not think the 1000W type is big enough.
    I think if you connect it and use the microwave you will destroy the step-down transformer.
My country use the 220 volts system do have to use a step down transformer of plug it in direct.it has been a year i have not used the appliance having no information on wattage
If your microwave is wired for 220 volts AC and your country standard house current is 220, and the plug is of the proper configuration, plug it in.
Standard microwave size is around 1100 watts at 110 volts Normally, two times the voltage is 1/2 the wattage. Ohms law, Voltares Law and Watts Law apply.
If your microwave is 1100 watts at 110 volts --- yes you will need a step- down transformer of some type.
Jul 12, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
I'm looking for a manual and drawings for the Lang deep Fat Fryer, type CLF-15-1 230 Volts, 60 hz
I am so glad I am able to help you -
Gary @ Fix Ya
Jul 11, 2011 | Microwave Ovens
Miele oven transformer broken. Need to find place to buy the part
hi,
you will have to purchase a new transformer from Miele or from a miele authorised dealer. you cannot purchase spare parts any other way.
if you look at www.miele.com and chose your country you will find your local Miele dealer or office
Apr 15, 2010 | Goldstar MV-1155 Microwave Oven
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
I need to install this range in a new kitchen and need to know the electical specs of the supply power
I don't see what range you're referencing. I see a title of microwave ovens. But, in any event, here's circuit requirement for each.
If it's a cooktop range: 220 volt 30 amp dedicated circuit
If it's a microwave: 110 volt 15 amp dedicated circuit
Charlie
Aug 22, 2009 | Microwave Ovens
Where can I find a operating manual for the KOG-574R microwave oven
Not knowing what country you're in, I'd say the best bet is to contact the dealer from whom you purchased it to see if they have contact information for Daewoo.
Jun 28, 2009 | Daewoo Microwave Ovens
ARE THERE INTERNAL FUSES IN MICROWAVES THAT CAN BURN OUT. MINE STOPPED WORKING ENTIRELY
There's usually an input line fuse on a small circuit board (part of an input line filter circuit) in most microwave ovens. This is usually a 20 amp appliance fuse that you can purchase at most major hardware stores (you would need to look at the fuse to verify the rating). You would need to remove the exterior cover to access the fuse. Its usually located near where the power cord enters the unit. Make sure you unplug the unit prior to attempting any repairs to the interior circuits. Microwave ovens are particularly dangerous as the the voltage potentials in the high voltage network are in the 3000-4000 volt range. In addition, most manufacturers provide a schematic drawing with troubleshooting advice behind the operator console, or inside the interior cabinet wall. I hope this helps you.
Aug 01, 2008 | Microwave Ovens
Paint inside microwave oven, Can it be repainted ?
Yes. You need to clean it, sand it shiny, then clean it squeky again.
Then you can get high temperature appliance paint in spray on brush-on form from local appliance part store or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Microwave Ovens
GE JES735WJ Microwave Oven Logo
116 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
